[gdal-dev] Maintenance report for Feb 24, 2010 to Mar 23, 2010
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Mar 24 01:08:30 EDT 2010
Skipped content of type multipart/alternative-------------- next part --------------
GDAL Maintenance Reports by Chaitanya kumar CH.
Duration: Feb 24, 2010 to Mar 23, 2010
#3434: Fixed the shapefile driver related to system specific directory seperator.
#3436: Added the INTERLEAVE value to the IMAGE_STRUCTURE domain for ENVIDataset. Also fixed the overflow check.
#3462: Reviewed  a fix to gdal_contour algorithm. Need to write a test script for further testing.
#3473: Caught a bug in GDALRasterizeLayers() that was revealed by a bug in the script tiff_write.py.
#3467: Applied a patch to fix a bug in OGRPolygon::PointOnSurface() and OGRPolygon::Centroid()
#3385: Applied a patch to fix problems caused by a call to unixODBC in some architectures.
#3480: Fixed the PG driver to differentiate system tables correctly.
Chaitanya kumar CH
chaitanyach at gmail.com
Duration: Jan 2, 2010 to Feb 22, 2010
#3354: Fixed some bugs and added multi-band initialization to gdal_merge.py
#3391: Fixed the mitab driver to create an OGRFeatureDefn for a newly created layer.
#3394: Fixed SQLite driver to report correct transaction capability.
#3402: Tested CPLError calls with a static string argument. I had a problem, probably related to linking wrong libraries.
#3335: Transaction support to CopyLayer()
#3396: Fixed a bug in GDALRasterizeLayers
Added some features to gdalbuildvrt and the VRT format to facilitate a user-defined background colour.
Chaitanya kumar CH
