[gdal-dev] field name in ESRI file
Oz Nahum
nahumoz at gmail.com
Wed Mar 24 12:09:09 EDT 2010
Hi Guys,
Thanks for everyone for the answers.
I'm sorry about the haste in sending the email. I've should have read more
carefully.
This issue is even in WIKIPEDIA ...
Oz.
On Wed, Mar 24, 2010 at 4:47 PM, Jason Roberts <jason.roberts at duke.edu>wrote:
> Oz,
> The specification that Peter refers to is
> http://www.esri.com/library/whitepapers/pdfs/shapefile.pdf. Also, check
> out the OGR Shapefile driver's documentation
> http://www.gdal.org/ogr/drv_shapefile.html. It documents this issue, as
> well as others that might be of interest. Finally, if you are interested in
> compatibility with ArcGIS,
> http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=Geoprocessing%20considerations%20for%20shapefile%20output
> In my experience, it is very important to read the OGR driver documentation
> carefully for whatever data format you're working with. The driver may
> exhibit different behavior than the original applications designed to work
> with that format. For example, the OGR shapefile driver documentation states
> that the default width for integer fields is 11 characters, which is the
> width required to fully represent 32-bit signed integers, yet the last link
> I mentioned above states that ArcGIS limits the width to 9 characters. You
> may want to carefully investigate issues like that if you are interested in
> compatibility with ArcGIS.
> Finally, the OGR driver documentation may occasionally document something
> better than the original documentation for the format. For example, the OGR
> shapefile driver documentation makes mention of storing dates in shapefiles.
> ArcGIS also supports storing dates in shapefiles yet ESRI's whitepaper makes
> no mention that shapefiles support dates.
> Best,
> Jason
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org [mailto:
> gdal-dev-bounces at lists.osgeo.org] On Behalf Of Peter J Halls
> Sent: Wednesday, March 24, 2010 11:15 AM
> To: Oz Nahum
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] field name in ESRI file
> Oz,
> shapefiles use the dBase IV format .dbf file for attributes: this defines
> the
> maximum field name width to be 10 characters - 'LAND USE CODE' has 13.
> Also,
> space characters are not permitted - use underscore '_' instead. Whilst
> GDAL
> may create the field names as you have specified, other packages may not
> accept
> them as input. I believe that the Shapefile rules are still available as a
> White Paper on the ESRI.com website: it is worth reading the document to
> understand what is possible.
> Best wishes,
> Peter
> Oz Nahum wrote:
> > Hello GDAL Devs,
> > I encoutered a small problem, where I don't understand why field names in
> > ESRI Shape files created by gdal, are truncated.
> > Here is a code snippet:
> > field_LUC = ogr.FieldDefn()
> > field_LUC.SetName('LAND USE CODE')
> > field_LUC.SetType(ogr.OFTInteger)
> > field_LUC.SetWidth(15)
> > dst_layer.CreateField(field_LUC)
> > Yet, when I examine the output file the attribute table contains a field
> > called "LAND USE C",
> > so 3 characters are missing.
> > Would be happy to know what am I doing wrong. Thank you very much,
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Peter J Halls, GIS Advisor, University of York
> Telephone: 01904 433806 Fax: 01904 433740
> Snail mail: Computing Service, University of York, Heslington, York YO10
> 5DD
> This message has the status of a private and personal communication
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100324/3e815ea2/attachment.html
