[gdal-dev] Re: Output MapInfo File with CoordSys Information
Reinaldo Escada Chohfi
reinaldo at geodesign.com.br
Wed Mar 24 15:31:48 EDT 2010
Frank,
It worked now.
Thanks a lot.
Regards,
Reinaldo
> Reinaldo Escada Chohfi wrote:
>> Hello Frank and List,
>> We waited for the release of GDAL 1.7.0 to see if we could output
>> MapInfo
>> Fiels (.tab or .mif/mid) with SRS information.
>> We still can not output .tab or .mif/mid files with SRS information.
>> Could you please check the test code below to see what's missing or
>> wrong?
>> void main()
>> OGRSpatialReference oSRS;
>> // oSRS.SetWellKnownGeogCS( "EPSG:4326" );
>> oSRS.importFromMICoordSys( "CoordSys Earth Projection 1, 104" );
>> OGRLayer *poLayer;
>> poLayer = poDS->CreateLayer( "test01", NULL, wkbPoint, NULL );
> Reinaldo,
> I don't see any sign that you are doing anything with the spatial
> reference. You need to pass the OGRSpatialReference* into CreateLayer()
> as the second argument.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
