[gdal-dev] rgdal source code
Ivan
ivan.lucena at pmldnet.com
Thu Mar 25 17:49:32 EDT 2010
Roger,
I in fact did my homework, but I've got a C.
As you can see on my previous message I did find the RGDAL Source Forge page where it shows the CVS
instructions ===> [1] <===. That would give a B+ at least, no? If it worked.
cvs -d:pserver:anonymous at rgdal.cvs.sourceforge.net:/cvsroot/rgdal login
Logging in to :pserver:anonymous at rgdal.cvs.sourceforge.net:2401/cvsroot/rgdal
CVS password:
cvs [login aborted]: connect to rgdal.cvs.sourceforge.net(216.34.181.108):2401 failed: Connection
refused
That was a dead end.
I download some of those zip packages from rgdal.sourceforge.net but they only have binary that
requires FWTools installation.
Another dead end.
But you are right I should have search a little more to find the CRAN page. So I am downloading
rgdal_0.6-2.5.zip now. Let's see how it goes.
Thanks you so very much Roger. Have a nice day.
Ivan
Roger Bivand wrote:
> Please, do your homework!
> Google on "R rgdal" gives:
> http://cran.r-project.org/web/packages/rgdal/index.html
> http://rgdal.sourceforge.net/
> where the latter says: "The R contributed package rgdal is available from
> CRAN", that is the first link. On CRAN you will find both the source tarball
> and a Windows 32-bit binary including 1.7.1 with standard drivers and expat
> for reading KML etc.
> The sourceforge site is used exclusively as a CVS repository for developers
> - it hasn't been used for software distribution since about 2004; the CRAN
> distribution mechanism is far more robust and "just works".
> Refer to show.file(system.file("README.windows", package="rgdal")) if you
> need to build from source for more exotic drivers.
> The relevant mailing list is R-sig-geo,
> https://www.stat.math.ethz.ch/mailman/listinfo/R-SIG-Geo/, and the best
> point of entrance, the R Spatial task view:
> http://cran.r-project.org/web/views/Spatial.html.
> Hope this helps,
> Roger
> Ivan-5 wrote:
>> Hi there,
>> I am trying to get RGDAL to work with GDAL 1.7.1 but I cannot access the
>> source code [1] and the binaries for Windows depend on some old version of
>> gdal_fw.dll. Does anybody have any clue?
>> Regards,
>> Ivan
>> [1] - http://sourceforge.net/scm/?type=cvs&group_id=84716
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Roger Bivand
> Economic Geography Section
> Department of Economics
> Norwegian School of Economics and Business Administration
> Helleveien 30
> N-5045 Bergen, Norway
