[gdal-dev] Area of hourglass shaped polygon
Chaitanya kumar CH
chaitanya.ch at gmail.com
Fri Mar 26 09:52:36 EDT 2010
Ramiro,
The C API function OGR_R_IsValid( OGRGeometryH ) may help you.
On Fri, Mar 26, 2010 at 2:02 AM, Ramiro Gonzalez <
ramirogonzalez at suremptec.com.ar> wrote:
> I won't calculate the area. I'll show an 'invalid area' message to the
> user.
> Thanks.
> 2010/3/19 Peter J Halls <P.Halls at york.ac.uk>
> Whilst I agree with Chris that the 'winding' method for calculating polygon
>> areas would need tweaking to work with a shape like this, the 'complementary
>> areas' method or the triangulation method would. See Stephen Wise, GIS
>> Basics, London: Taylor & Francis (2002) pp61-64 or Joseph O'Rourke,
>> Computational Geometry in C, Cambridge (2nd Edn): Cambridge University Press
>> (1998) pp18-22.
>> Best wishes,
>> Peter
>> Chris 'Xenon' Hanson wrote:
>>> On 3/18/2010 10:20 AM, Ramiro Gonzalez wrote:
>>>> I use gdal to calculate the area of polygons drawn by a user over a map.
>>>> The points are added to the polygon in same order the user selects them.
>>>> An hourglass shaped polygon can be created adding 4 points like a 'z'.
>>>> When the polygon has the shape of an hourglass, the measure returned by
>>>> get_Area() is smaller than the sum of the areas of the two independent
>>>> triangles.
>>>> I'd like to know if there is a way to calculate the area in this
>>>> situation?
>>>> I tried to intersect the polygon with another that contains it but the
>>>> operation fails when the polygon cross itself(return NULL). I could use
>>>> this to inform that the area calculated is invalid, but I'd like to know
>>>> if there is a better way of knowing this.
>>> I'm pretty sure this would be considered nonsensical topology. Area
>>> calculations usually
>>> rely on the points in a polygon winding either consistently clockwise or
>>> counter-clockwise, but yours are mixed.
>>> Don't do that. It's bad.
>>> If you want to measure the area of a shape like that, create it out of
>>> two normal
>>> consistently-wound triangles stacked tip-to-tip.
>>> Thanks,
>>>> Ramiro
>> Peter J Halls, GIS Advisor, University of York
>> Telephone: 01904 433806 Fax: 01904 433740
>> Snail mail: Computing Service, University of York, Heslington, York YO10
>> 5DD
>> This message has the status of a private and personal communication
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100326/6ce249b9/attachment-0001.html
