[gdal-dev] Converting contour lines (Shape files) into DEM
Tue Mar 30 08:12:20 EDT 2010
Jan Hartmann wrote:
> Frank, is there a description of the way the smoothing is done, or
> should I look it up in the code?
Jan,
It does a user defined number of iterations of 3x3 average filtering,
only altering the interpolated pixels.   The algorithm discussion,
such as it is, is attached to the API function:
http://gdal.org/gdal__alg_8h.html#0a079afef61968f224b159d48423d1c6
> BTW: there is a description of the algorithm used in GRASS to create
> contour lines:
> https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.contour/README
> This looks much more adapted to the specific case of contour lines than
> the general weighted distance model in GDAL (which is the best one for
> general purposes IMHO). Would it make sense/be possible to adapt the
> GRASS code for GDAL? Doesn't look all too difficult to me.
st regards,
My reading of r.contour is that it creates contours from a raster, the
process equivelent to what gdal_contour does, not gdal_rasterize + gdal_fillnodata.
Best regards,
