[gdal-dev] Re: KyngChaos Frameworks: GDAL's numpy vs Enthought's
numpy
K.-Michael Aye
kmichael.aye at gmail.com
Tue May 4 10:49:09 EDT 2010
On 2010-05-04 16:30:53 +0200, William Kyngesburye said:
> Huh, did Enthought update their numpy also? If not, I'd expect the
> sameproblems.
you expect the same problems for the situation
EPD: Numpy 1.4.0 and GDAL: Numpy 1.4.1
then for my previous situation:
EPD: Numpy 1.4.0 and GDAL: Numpy 1.3?
I did nothing to the EPD installation.
I copied your gdal.pth from Resources to
~/Library/Python/Versions/2.6/site-packages, could now run ipython with
the -pylab switch and plot data with EPD's matplotlib, that I received
before from GDAL's ReadAsArray.
> On May 4, 2010, at 9:19 AM, K.-Michael Aye wrote:
>> ahh, thank you very much! Thanks to your update using Numpy1.4.1
>> Isuccessfully married your GDAL frameworks with EPD.
>> and I lived happily ever after having all I needed.. (that is, untilthe
>> next cool software comes along. ;)
>> Have a great week!
>> Best regards,
>> Michael
>> On 2010-04-30 16:13:35 +0200, William Kyngesburye said:
>>> Thanks. I probably would have forgotten to check before
>>> buildingandpackaging GDAL 1.7.2 this weekend.
>>> On Apr 30, 2010, at 8:54 AM, K.-Michael Aye wrote:
>>>> Hi William,
>>>> Numpy1.4.1 has been released, just to let you know. *hint,hint* ;)
>>>> Best regards and a nice weekend!
>>>> Michael
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/
>>> "The beast is actively interested only in now, and, as it is
>>> alwaysnowand always shall be, there is an eternity of time for
>>> theaccomplishmentof objects."
>>> - the wisdom of Tarzan
> "The beast is actively interested only in now, and, as it is always
> nowand always shall be, there is an eternity of time for the
