[gdal-dev] Will gdalinfo generate the pam .aux.xml files?
Rubin, Jared JARED.RUBIN at saic.com
Thu May 6 17:09:52 EDT 2010
I am using gdal-1.6.2 (version not important) and would like for gdalinfo to generate  .aux.xml files  for NITF files that I have on disk, is this possible?
If this is possible, will gdalinfo just load an  image.nitf.aux.xml file instead of image.nitf?
Thanks
Jared
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100506/270e9be0/attachment.html
