[gdal-dev] Obtain more information with Ogrinfo
Daniele Romagnoli
daniele.romagnoli at geo-solutions.it
Mon May 10 06:10:57 EDT 2010
Hi Antònio,
once you get the name of the layer, (1: training_data_AA_NAC_N_M (Polygon)),
you can redo the command by specifying also the layer name:
As an instance,
ogrinfo filename.shp training_data_AA_NAC_N_M
Hope this helps.
Regards,
Daniele
2010/5/10 António Rocha <antonio.rocha at deimos.com.pt>
> Greetings
> I need to obtain a little bit more information regarding a Shapefile. I
> have done ogrinfo <filename> but I only obtained:
> INFO: Open of `file.shp'
> using driver `ESRI Shapefile' successful.
> I mean it only identified me the sub-dataset and the data-format. I need
> information regarding projection/coordinates. How can I obtain it?
> Thanks
> Antonio
> __________ Information from ESET NOD32 Antivirus, version of virus
> signature database 5100 (20100510) __________
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Eng. Daniele Romagnoli
Software Engineer
GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
Italy
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
http://www.geo-solutions.it
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100510/a33d2f19/attachment.html
