[gdal-dev] Will gdalinfo generate the pam .aux.xml files?
Matt Wilkie matt.wilkie at gov.yk.ca
Mon May 10 15:07:27 EDT 2010
On 10/05/2010 11:40 AM, Chaitanya kumar CH wrote:
> Check if gdalinfo creates the xml files when used with the -stats option
> on your images.
But be careful with 32bit float rasters. I just filed a bug on "gdalinfo
-stats" not computing min/max properly on these,
http://trac.osgeo.org/gdal/ticket/3573
-matt
