[gdal-dev] get different result when use different parameters
weixj2003ld weixj2003ld at 163.com
Mon May 10 23:16:55 EDT 2010
I download a elevation data (SRTM,GTOPO30) from http://glcfapp.glcf.umd.edu:8080/esdi/index.jsp
 use
and
differently,
with parameter 'UInt16',I get a black picture,with Byte,get a different one,why?
BTW,I want to get a png file from elevation data(.tif),must I use command gdal_translate?
Thk u in advance.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100511/473b907e/attachment.html
