[gdal-dev] Python (2.6.5) GDAL module will not install with
easy_install
Allen Rongone
arongone at aer.com
Tue May 11 13:13:28 EDT 2010
Brice,
I think I was using the tarball specific to the python module. I
think I downloaded the correct one now - gdal-1.7.2.tar.gz
I ran the configure script as such:
# ./configure --prefix=/opt/GOESR/local --with-python
Then a make
# make
Then a make install
# make install
Everything seemed fine until I tried to import the module in python.
I got this when I tried:
> [root at psd14 gdal-1.7.2]# python
> Python 2.6.5 (r265:79063, May 3 2010, 14:23:56)
> [GCC 4.1.2 20080704 (Red Hat 4.1.2-46)] on linux2
> Type "help", "copyright", "credits" or "license" for more information.
> >>> from osgeo import gdal
> Traceback (most recent call last):
> File "<stdin>", line 1, in <module>
> File "/opt/GOESR/local/lib/python2.6/site-packages/GDAL-1.7.2-
> py2.6-linux-x86_64.egg/osgeo/__init__.py", line 21, in <module>
> _gdal = swig_import_helper()
> py2.6-linux-x86_64.egg/osgeo/__init__.py", line 17, in
> swig_import_helper
> _mod = imp.load_module('_gdal', fp, pathname, description)
> ImportError: /opt/GOESR/local/lib/python2.6/site-packages/GDAL-1.7.2-
> py2.6-linux-x86_64.egg/osgeo/_gdal.so: undefined symbol:
> GDALGetMaskFlags
Any ideas why I'm getting the ImportError with the undefined symbol?
Thank you very much for your help,
Allen Rongone
On May 6, 2010, at 12:47 PM, Brice Lambi wrote:
> Hi Allen,
> Are you compiling from source? When I install gdal python I just go
> into the swig/python directory and run 'python setup.py install'.
> This
> should work. The steps I take:
> tar zxvf gdal-1.7.1.tar.gz
> cd gdal-1.7.1
> ./configure --prefix=/usr
> make
> make install #run as root
> cd swig/python
> python setup.py install #run as root
> Hope this helps.
> Cheers,
> Brice
> Allen Rongone wrote:
>> Hello All,
>> New here so don't beat me up to bad.
>> I'm trying to get the GDAL module to install on a Red Hat
>> Enterprise
>> Linux 5.4 64-bit workstation running Python 2.6.5.
>> I have installed the setuptools 0.6c11 and am using easy_install
>> My gdal-config is in /usr/bin, however, when I run easy_install
>> GDAL
>> it complains that it "Could not run gdal-config!!!" and then
>> contiues on
>> complaining about a bunch of stuff not
>> being declared.
>> I can not find the setup.py to edit and change the location of
>> gdal-config. easy_install must clean everything up if it fails.
>> Does anyone know how to get this to work or will we have to do
>> without GDAL in python?
>> Thanks for any help,
>> Allen
>> I've included everything I thought pertinent below:
>> [root at psd14 ~]# uname -a
>> Linux psd14.aer.com 2.6.18-164.15.1.el5 #1 SMP Mon Mar 1 10:56:08 EST
>> 2010 x86_64 x86_64 x86_64 GNU/Linux
>> [root at psd14 ~]# python
>> information.
>> KeyboardInterrupt
>> [root at psd14 ~]# which gdal-config
>> /usr/bin/gdal-config
>> [root at psd14 ~]# easy_install GDAL
>> Searching for GDAL
>> Reading http://pypi.python.org/simple/GDAL/
>> Reading http://www.gdal.org
>> Best match: GDAL 1.7.1
>> Downloading
>> http://pypi.python.org/packages/source/G/GDAL/
>> GDAL-1.7.1.tar.gz#md5=38b838d528b309a28a3aa24d4fcef3cd
>> Processing GDAL-1.7.1.tar.gz
>> Running GDAL-1.7.1/setup.py -q bdist_egg --dist-dir
>> /tmp/easy_install-eKZHzW/GDAL-1.7.1/egg-dist-tmp-siVuDI
>> Could not run gdal-config!!!!
>> cc1plus: warning: command line option "-Wstrict-prototypes" is
>> valid for
>> Ada/C/ObjC but not for C++
>> extensions/gdal_wrap.cpp: In function $(B!F(Bint
>> GDALDriverShadow_Rename(GDALDriverShadow*, const char*, const
>> char*)$(B!G(B:
>> extensions/gdal_wrap.cpp:3371: error:
>> $(B!F(BGDALRenameDataset$(B!G(B was not declared in this scope
>> extensions/gdal_wrap.cpp: In function $(B!F(BCPLErr
>> GDALDatasetShadow_CreateMaskBand(GDALDatasetShadow*, int)$(B!G(B:
>> extensions/gdal_wrap.cpp:3744: error:
>> $(B!F(BGDALCreateDatasetMaskBand$(B!G(B was not declared in
>> this scope
>> extensions/gdal_wrap.cpp: In function $(B!F(Bchar**
>> GDALDatasetShadow_GetFileList(GDALDatasetShadow*)$(B!G(B:
>> extensions/gdal_wrap.cpp:3747: error: $(B!F(BGDALGetFileList$(B!
>> G(B
>> extensions/gdal_wrap.cpp: In function $(B!F(BGDALRasterBandShadow*
>> GDALRasterBandShadow_GetMaskBand(GDALRasterBandShadow*)$(B!G(B:
>> extensions/gdal_wrap.cpp:4077: error: $(B!F(BGDALGetMaskBand$(B!
>> G(B
>> GDALRasterBandShadow_GetMaskFlags(GDALRasterBandShadow*)$(B!G(B:
>> extensions/gdal_wrap.cpp:4080: error: $(B!F(BGDALGetMaskFlags$(B!
>> G(B
>> GDALRasterBandShadow_CreateMaskBand(GDALRasterBandShadow*, int)$(B!
>> G(B:
>> extensions/gdal_wrap.cpp:4083: error:
>> $(B!F(BGDALCreateMaskBand$(B!G(B was not declared in this scope
>> extensions/gdal_wrap.cpp: In function $(B!F(Bvoid
>> GDALColorTableShadow_CreateColorRamp(GDALColorTableShadow*, int,
>> const
>> GDALColorEntry*, int, const GDALColorEntry*)$(B!G(B:
>> extensions/gdal_wrap.cpp:4147: error:
>> $(B!F(BGDALCreateColorRamp$(B!G(B was not declared in this scope
>> ComputeProximity(GDALRasterBandShadow*, GDALRasterBandShadow*,
>> char**,
>> int (*)(double, const char*, void*), void*)$(B!G(B:
>> extensions/gdal_wrap.cpp:4306: error:
>> $(B!F(BGDALComputeProximity$(B!G(B was not declared in this scope
>> RasterizeLayer(GDALDatasetShadow*, int, int*, OGRLayerShadow*, void*,
>> void*, int, double*, char**, int (*)(double, const char*, void*),
>> void*)$(B!G(B:
>> extensions/gdal_wrap.cpp:4342: error:
>> $(B!F(BGDALRasterizeLayers$(B!G(B was not declared in this scope
>> Polygonize(GDALRasterBandShadow*, GDALRasterBandShadow*,
>> OGRLayerShadow*, int, char**, int (*)(double, const char*, void*),
>> void*)$(B!G(B:
>> extensions/gdal_wrap.cpp:4362: error: $(B!F(BGDALPolygonize$(B!
>> G(B
>> FillNodata(GDALRasterBandShadow*, GDALRasterBandShadow*, double, int,
>> char**, int (*)(double, const char*, void*), void*)$(B!G(B:
>> extensions/gdal_wrap.cpp:4378: error: $(B!F(BGDALFillNodata$(B!
>> G(B
>> SieveFilter(GDALRasterBandShadow*, GDALRasterBandShadow*,
>> GDALRasterBandShadow*, int, int, char**, int (*)(double, const char*,
>> extensions/gdal_wrap.cpp:4394: error: $(B!F(BGDALSieveFilter$(B!
>> G(B
>> RegenerateOverviews(GDALRasterBandShadow*, int,
>> GDALRasterBandShadow**,
>> const char*, int (*)(double, const char*, void*), void*)$(B!G(B:
>> extensions/gdal_wrap.cpp:4408: error: invalid conversion from
>> $(B!F(BGDALRasterBandShadow*$(B!G(B to $(B!F(BGDALRasterBand*
>> $(B!G
>> (Bextensions/gdal_wrap.cpp:4408: error: initializing argument 1
>> of $(B!F(BCPLErr GDALRegenerateOverviews(GDALRasterBand*, int,
>> GDALRasterBand**, const char*, int (*)(double, const char*, void*),
>> void*)$(B!G
>> (Bextensions/gdal_wrap.cpp:4408: error: invalid conversion from
>> $(B!F(BGDALRasterBandShadow**$(B!G(B to $(B!
>> F(BGDALRasterBand**$(B!G
>> (Bextensions/gdal_wrap.cpp:4408: error: initializing argument 3
>> void*)$(B!G
>> (Bextensions/gdal_wrap.cpp: In function $(B!F(Bint
>> RegenerateOverview(GDALRasterBandShadow*, GDALRasterBandShadow*,
>> const
>> extensions/gdal_wrap.cpp:4421: error: invalid conversion from
>> $(B!G
>> (Bextensions/gdal_wrap.cpp:4421: error: initializing argument 1
>> void*)$(B!G
>> (Bextensions/gdal_wrap.cpp:4421: error: invalid conversion from
>> (Bextensions/gdal_wrap.cpp:4421: error: initializing argument 3
>> void*)$(B!G
>> $(B!F(BGDALTransformerInfoShadow*
>> new_GDALTransformerInfoShadow(GDALDatasetShadow*,
>> GDALDatasetShadow*, char**)$(B!G(B:
>> extensions/gdal_wrap.cpp:4445: error:
>> $(B!F(BGDALCreateGenImgProjTransformer2$(B!G(B was not declared
>> in
>> this scope
>> GDALTransformerInfoShadow_TransformPoint__SWIG_0
>> (GDALTransformerInfoShadow*,
>> int, double*)$(B!G(B:
>> extensions/gdal_wrap.cpp:4456: error:
>> $(B!F(BGDALUseTransformer$(B!G(B was not declared in this scope
>> GDALTransformerInfoShadow_TransformPoint__SWIG_1
>> double*, int, double, double, double)$(B!G(B:
>> extensions/gdal_wrap.cpp:4468: error:
>> GDALTransformerInfoShadow_TransformPoints(GDALTransformerInfoShadow*,
>> int, int, double*, double*, double*, int*)$(B!G(B:
>> extensions/gdal_wrap.cpp:4550: error:
>> extensions/gdal_wrap.cpp: In function $(B!F(BGDALDriverShadow*
>> IdentifyDriver(const char*, char**)$(B!G(B:
>> extensions/gdal_wrap.cpp:4661: error:
>> $(B!F(BGDALIdentifyDriver$(B!G(B was not declared in this scope
>> extensions/gdal_wrap.cpp: In function $(B!F(BPyObject*
>> _wrap_ReadDir(PyObject*, PyObject*)$(B!G(B:
>> extensions/gdal_wrap.cpp:5255: error: $(B!F(BVSIReadDir$(B!G(B
>> was
>> error: Setup script exited with error: command 'gcc' failed with exit
>> status 1
>> [root at psd14 ~]#
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
