[gdal-dev] Python (2.6.5) GDAL module will not install with
easy_install
Brice Lambi
lambi at ucar.edu
Tue May 11 15:57:48 EDT 2010
There is really no reason to remove the 1.7.2 you've built. If you're
going to install in the same location then all will be overwritten, if
you install in a new location then it might be best to cleanup the
unused stuff. I think you can do 'make uninstall' as well.
Cheers,
Brice
Allen Rongone wrote:
> Brice,
> Thank you for all your help. However, I did want to know if I need
> to back out all the gdal-1.7.2 I just installed before I start over, or
> can I just run the make clean/ configure /make /make install, again
> after I remove the old gdal from the system? And if so, how would that
> be done?
> Thanks again,
> Allen
> On May 11, 2010, at 2:10 PM, Brice Lambi wrote:
>> It really looks like a linking error, make sure that
>> /opt/GOESR/local/lib is in your LD_LIBRARY_PATH before /usr/lib or
>> /usr/local/lib. If you won't use it, it would probably be best to
>> remove all gdal stuff from yum just to avoid any confusion.
>> Also when you ran python setup.py install in the swig/python area make
>> sure you see something like -L/opt/GEOSR/local/lib in the compiler
>> commands flying across your screen. If you don't see this, and your
>> LD_LIBRARY_PATH isn't setup it is probably still trying to use something
>> in /usr/
>> Good luck,
>> Brice
>>> On May 11, 2010, at 1:19 PM, Brice Lambi wrote:
>>>> What is your python path?
>>>> # python
>>>>>>> import sys
>>>>>>> sys.path
>>>> What does that say? It might have linked against the wrong version of
>>>> gdal or it might be finding another gdal library in your path. If you
>>>> are using the default python (/usr/bin/python) it is probably finding
>>>> something in /usr/lib before /opt/GEOSR/local.
>>> Here is the output from the command above:
>>> [root at psd14 ~]# python
>>> Python 2.6.5 (r265:79063, May 3 2010, 14:23:56)
>>> [GCC 4.1.2 20080704 (Red Hat 4.1.2-46)] on linux2
>>> Type "help", "copyright", "credits" or "license" for more information.
>>>>>> import sys
>>>>>> sys.path
>>> '/opt/GOESR/local/lib/python2.6/site-packages/setuptools-0.6c11-py2.6.egg',
>>> '/opt/GOESR/local/lib/python2.6/site-packages/numpy-1.4.1-py2.6-linux-x86_64.egg',
>>> '/opt/GOESR/local/lib/python2.6/site-packages/scipy-0.7.2-py2.6-linux-x86_64.egg',
>>> '/opt/GOESR/local/lib/python2.6/site-packages/matplotlib-0.99.1.1-py2.6-linux-x86_64.egg',
>>> '/opt/GOESR/local/lib/python2.6/site-packages/GDAL-1.7.2-py2.6-linux-x86_64.egg',
>>> '/opt/GOESR/local/lib/python26.zip', '/opt/GOESR/local/lib/python2.6',
>>> '/opt/GOESR/local/lib/python2.6/plat-linux2',
>>> '/opt/GOESR/local/lib/python2.6/lib-tk',
>>> '/opt/GOESR/local/lib/python2.6/lib-old',
>>> '/opt/GOESR/local/lib/python2.6/lib-dynload',
>>> '/opt/GOESR/local/lib/python2.6/site-packages']
>>> [root at psd14 ~]# which python
>>> /opt/GOESR/local/bin/python
>>> There still exists version 1.4.4 of gdal and gdal-devel from the Red Hat
>>> build, on this system, but they don't show up in the path.
>>> Is there a way to back out everything?
>>> Then I could remove gdal 1.4.4. with yum and try to install from the
>>> tarball again.
>>> Does this make sense?
>>> Sorry for all the trouble...
>>> ~ Allen
>>>>> Brice,
>>>>> I think I was using the tarball specific to the python module. I
>>>>> think I downloaded the correct one now - gdal-1.7.2.tar.gz
>>>>> I ran the configure script as such:
>>>>> # ./configure --prefix=/opt/GOESR/local --with-python
>>>>> Then a make
>>>>> # make
>>>>> Then a make install
>>>>> # make install
>>>>> Everything seemed fine until I tried to import the module in python.
>>>>> I got this when I tried:
>>>>>> [root at psd14 gdal-1.7.2]# python
>>>>>> information.
>>>>>>>>> from osgeo import gdal
>>>>>> Traceback (most recent call last):
>>>>>> File "<stdin>", line 1, in <module>
>>>>>> File
>>>>>> "/opt/GOESR/local/lib/python2.6/site-packages/GDAL-1.7.2-py2.6-linux-x86_64.egg/osgeo/__init__.py",
>>>>>> line 21, in <module>
>>>>>> _gdal = swig_import_helper()
>>>>>> File
>>>>>> line 17, in swig_import_helper
>>>>>> _mod = imp.load_module('_gdal', fp, pathname, description)
>>>>>> ImportError:
>>>>>> /opt/GOESR/local/lib/python2.6/site-packages/GDAL-1.7.2-py2.6-linux-x86_64.egg/osgeo/_gdal.so:
>>>>>> undefined symbol: GDALGetMaskFlags
>>>>> Any ideas why I'm getting the ImportError with the undefined symbol?
>>>>> Thank you very much for your help,
>>>>> Allen Rongone
>>>>> On May 6, 2010, at 12:47 PM, Brice Lambi wrote:
>>>>>> Hi Allen,
>>>>>> Are you compiling from source? When I install gdal python I just go
>>>>>> into the swig/python directory and run 'python setup.py install'.
>>>>>> This
>>>>>> should work. The steps I take:
>>>>>> tar zxvf gdal-1.7.1.tar.gz
>>>>>> cd gdal-1.7.1
>>>>>> ./configure --prefix=/usr
>>>>>> make
>>>>>> make install #run as root
>>>>>> cd swig/python
>>>>>> python setup.py install #run as root
>>>>>> Hope this helps.
>>>>>> Cheers,
>>>>>> Brice
>>>>>>> Hello All,
>>>>>>> New here so don't beat me up to bad.
>>>>>>> I'm trying to get the GDAL module to install on a Red Hat
>>>>>>> Enterprise
>>>>>>> Linux 5.4 64-bit workstation running Python 2.6.5.
>>>>>>> I have installed the setuptools 0.6c11 and am using easy_install
>>>>>>> My gdal-config is in /usr/bin, however, when I run easy_install
>>>>>>> GDAL
>>>>>>> it complains that it "Could not run gdal-config!!!" and then
>>>>>>> contiues on
>>>>>>> complaining about a bunch of stuff not
>>>>>>> being declared.
>>>>>>> I can not find the setup.py to edit and change the location of
>>>>>>> gdal-config. easy_install must clean everything up if it fails.
>>>>>>> Does anyone know how to get this to work or will we have to do
>>>>>>> without GDAL in python?
>>>>>>> Thanks for any help,
>>>>>>> Allen
>>>>>>> I've included everything I thought pertinent below:
>>>>>>> [root at psd14 ~]# uname -a
>>>>>>> Linux psd14.aer.com 2.6.18-164.15.1.el5 #1 SMP Mon Mar 1 10:56:08
>>>>>>> EST
>>>>>>> 2010 x86_64 x86_64 x86_64 GNU/Linux
>>>>>>> information.
>>>>>>> KeyboardInterrupt
>>>>>>> [root at psd14 ~]# which gdal-config
>>>>>>> /usr/bin/gdal-config
>>>>>>> [root at psd14 ~]# easy_install GDAL
>>>>>>> Searching for GDAL
>>>>>>> Reading http://pypi.python.org/simple/GDAL/
>>>>>>> Reading http://www.gdal.org
>>>>>>> Best match: GDAL 1.7.1
>>>>>>> Downloading
>>>>>>> http://pypi.python.org/packages/source/G/GDAL/GDAL-1.7.1.tar.gz#md5=38b838d528b309a28a3aa24d4fcef3cd
>>>>>>> Processing GDAL-1.7.1.tar.gz
>>>>>>> Running GDAL-1.7.1/setup.py -q bdist_egg --dist-dir
>>>>>>> /tmp/easy_install-eKZHzW/GDAL-1.7.1/egg-dist-tmp-siVuDI
>>>>>>> Could not run gdal-config!!!!
>>>>>>> cc1plus: warning: command line option "-Wstrict-prototypes" is
>>>>>>> valid for
>>>>>>> Ada/C/ObjC but not for C++
>>>>>>> extensions/gdal_wrap.cpp: In function $(B!F(Bint
>>>>>>> GDALDriverShadow_Rename(GDALDriverShadow*, const char*, const
>>>>>>> char*)$(B!G(B:
>>>>>>> extensions/gdal_wrap.cpp:3371: error:
>>>>>>> $(B!F(BGDALRenameDataset$(B!G(B was not declared in this scope
>>>>>>> extensions/gdal_wrap.cpp: In function $(B!F(BCPLErr
>>>>>>> GDALDatasetShadow_CreateMaskBand(GDALDatasetShadow*, int)$(B!G(B:
>>>>>>> extensions/gdal_wrap.cpp:3744: error:
>>>>>>> $(B!F(BGDALCreateDatasetMaskBand$(B!G(B was not declared in this
>>>>>>> scope
>>>>>>> extensions/gdal_wrap.cpp: In function $(B!F(Bchar**
>>>>>>> GDALDatasetShadow_GetFileList(GDALDatasetShadow*)$(B!G(B:
>>>>>>> extensions/gdal_wrap.cpp:3747: error:
>>>>>>> $(B!F(BGDALGetFileList$(B!G(B
>>>>>>> extensions/gdal_wrap.cpp: In function $(B!F(BGDALRasterBandShadow*
>>>>>>> GDALRasterBandShadow_GetMaskBand(GDALRasterBandShadow*)$(B!G(B:
>>>>>>> extensions/gdal_wrap.cpp:4077: error:
>>>>>>> $(B!F(BGDALGetMaskBand$(B!G(B
>>>>>>> GDALRasterBandShadow_GetMaskFlags(GDALRasterBandShadow*)$(B!G(B:
>>>>>>> extensions/gdal_wrap.cpp:4080: error:
>>>>>>> $(B!F(BGDALGetMaskFlags$(B!G(B
>>>>>>> GDALRasterBandShadow_CreateMaskBand(GDALRasterBandShadow*,
>>>>>>> int)$(B!G(B:
>>>>>>> extensions/gdal_wrap.cpp:4083: error:
>>>>>>> $(B!F(BGDALCreateMaskBand$(B!G(B was not declared in this scope
>>>>>>> extensions/gdal_wrap.cpp: In function $(B!F(Bvoid
>>>>>>> GDALColorTableShadow_CreateColorRamp(GDALColorTableShadow*, int,
>>>>>>> const
>>>>>>> GDALColorEntry*, int, const GDALColorEntry*)$(B!G(B:
>>>>>>> extensions/gdal_wrap.cpp:4147: error:
>>>>>>> $(B!F(BGDALCreateColorRamp$(B!G(B was not declared in this scope
>>>>>>> ComputeProximity(GDALRasterBandShadow*, GDALRasterBandShadow*,
>>>>>>> char**,
>>>>>>> int (*)(double, const char*, void*), void*)$(B!G(B:
>>>>>>> extensions/gdal_wrap.cpp:4306: error:
>>>>>>> $(B!F(BGDALComputeProximity$(B!G(B was not declared in this
>>>>>>> scope
>>>>>>> RasterizeLayer(GDALDatasetShadow*, int, int*, OGRLayerShadow*,
>>>>>>> void*,
>>>>>>> void*, int, double*, char**, int (*)(double, const char*, void*),
>>>>>>> void*)$(B!G(B:
>>>>>>> extensions/gdal_wrap.cpp:4342: error:
>>>>>>> $(B!F(BGDALRasterizeLayers$(B!G(B was not declared in this scope
>>>>>>> Polygonize(GDALRasterBandShadow*, GDALRasterBandShadow*,
>>>>>>> OGRLayerShadow*, int, char**, int (*)(double, const char*, void*),
>>>>>>> void*)$(B!G(B:
>>>>>>> extensions/gdal_wrap.cpp:4362: error:
>>>>>>> $(B!F(BGDALPolygonize$(B!G(B
>>>>>>> FillNodata(GDALRasterBandShadow*, GDALRasterBandShadow*, double,
>>>>>>> int,
>>>>>>> char**, int (*)(double, const char*, void*), void*)$(B!G(B:
>>>>>>> extensions/gdal_wrap.cpp:4378: error:
>>>>>>> $(B!F(BGDALFillNodata$(B!G(B
>>>>>>> SieveFilter(GDALRasterBandShadow*, GDALRasterBandShadow*,
>>>>>>> GDALRasterBandShadow*, int, int, char**, int (*)(double, const
>>>>>>> char*,
>>>>>>> extensions/gdal_wrap.cpp:4394: error:
>>>>>>> $(B!F(BGDALSieveFilter$(B!G(B
>>>>>>> RegenerateOverviews(GDALRasterBandShadow*, int,
>>>>>>> GDALRasterBandShadow**,
>>>>>>> const char*, int (*)(double, const char*, void*), void*)$(B!G(B:
>>>>>>> extensions/gdal_wrap.cpp:4408: error: invalid conversion from
>>>>>>> $(B!F(BGDALRasterBandShadow*$(B!G(B to
>>>>>>> $(B!F(BGDALRasterBand*$(B!G
>>>>>>> (Bextensions/gdal_wrap.cpp:4408: error: initializing argument 1
>>>>>>> of $(B!F(BCPLErr GDALRegenerateOverviews(GDALRasterBand*, int,
>>>>>>> GDALRasterBand**, const char*, int (*)(double, const char*, void*),
>>>>>>> void*)$(B!G
>>>>>>> (Bextensions/gdal_wrap.cpp:4408: error: invalid conversion from
>>>>>>> $(B!F(BGDALRasterBandShadow**$(B!G(B to
>>>>>>> $(B!F(BGDALRasterBand**$(B!G
>>>>>>> (Bextensions/gdal_wrap.cpp:4408: error: initializing argument 3
>>>>>>> void*)$(B!G
>>>>>>> (Bextensions/gdal_wrap.cpp: In function $(B!F(Bint
>>>>>>> RegenerateOverview(GDALRasterBandShadow*, GDALRasterBandShadow*,
>>>>>>> const
>>>>>>> extensions/gdal_wrap.cpp:4421: error: invalid conversion from
>>>>>>> (Bextensions/gdal_wrap.cpp:4421: error: initializing argument 1
>>>>>>> void*)$(B!G
>>>>>>> (Bextensions/gdal_wrap.cpp:4421: error: invalid conversion from
>>>>>>> (Bextensions/gdal_wrap.cpp:4421: error: initializing argument 3
>>>>>>> void*)$(B!G
>>>>>>> $(B!F(BGDALTransformerInfoShadow*
>>>>>>> new_GDALTransformerInfoShadow(GDALDatasetShadow*,
>>>>>>> GDALDatasetShadow*, char**)$(B!G(B:
>>>>>>> extensions/gdal_wrap.cpp:4445: error:
>>>>>>> $(B!F(BGDALCreateGenImgProjTransformer2$(B!G(B was not
>>>>>>> declared in
>>>>>>> this scope
>>>>>>> GDALTransformerInfoShadow_TransformPoint__SWIG_0(GDALTransformerInfoShadow*,
>>>>>>> int, double*)$(B!G(B:
>>>>>>> extensions/gdal_wrap.cpp:4456: error:
>>>>>>> $(B!F(BGDALUseTransformer$(B!G(B was not declared in this scope
>>>>>>> GDALTransformerInfoShadow_TransformPoint__SWIG_1(GDALTransformerInfoShadow*,
>>>>>>> double*, int, double, double, double)$(B!G(B:
>>>>>>> extensions/gdal_wrap.cpp:4468: error:
>>>>>>> GDALTransformerInfoShadow_TransformPoints(GDALTransformerInfoShadow*,
>>>>>>> int, int, double*, double*, double*, int*)$(B!G(B:
>>>>>>> extensions/gdal_wrap.cpp:4550: error:
>>>>>>> extensions/gdal_wrap.cpp: In function $(B!F(BGDALDriverShadow*
>>>>>>> IdentifyDriver(const char*, char**)$(B!G(B:
>>>>>>> extensions/gdal_wrap.cpp:4661: error:
>>>>>>> $(B!F(BGDALIdentifyDriver$(B!G(B was not declared in this scope
>>>>>>> extensions/gdal_wrap.cpp: In function $(B!F(BPyObject*
>>>>>>> _wrap_ReadDir(PyObject*, PyObject*)$(B!G(B:
>>>>>>> extensions/gdal_wrap.cpp:5255: error:
>>>>>>> $(B!F(BVSIReadDir$(B!G(B was
>>>>>>> error: Setup script exited with error: command 'gcc' failed with
>>>>>>> exit
>>>>>>> status 1
>>>>>>> [root at psd14 ~]#
>>>>>>> _______________________________________________
>>>>>>> gdal-dev mailing list
>>>>>>> gdal-dev at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
