[gdal-dev] gdalwarp's default nodata value
Joaquim Luis
jluis at ualg.pt
Wed May 12 17:15:08 EDT 2010
Even,
Thanks, I understand it better now and made some advances but I'm still facing some troubles.
For example, if I do this
papszWarpOptions = CSLSetNameValue(papszWarpOptions, "INIT_DEST", "300" );
psWO->papszWarpOptions = CSLDuplicate(papszWarpOptions);
than it works fine.
However, if I do (remember that I want NaNs)
papszWarpOptions = CSLSetNameValue(papszWarpOptions, "INIT_DEST", "nan" );
than I get zeros again in place of the nodata.
The link you pointed me says
"...or INIT_DEST=NO_DATA: This option forces the destination image to be initialized to the
indicated value (for all bands) or indicates that it should be initialized to the NO_DATA value in
padfDstNoDataReal/padfDstNoDataImag."
So I next tried
papszWarpOptions = CSLSetNameValue(papszWarpOptions, "INIT_DEST", "NO_DATA" );
psWO->padfSrcNoDataReal = (double *) CPLMalloc(psWO->nBandCount*sizeof(double));
psWO->padfSrcNoDataImag = (double *) CPLMalloc(psWO->nBandCount*sizeof(double));
for (i = 0; i < nBands; i++) {
psWO->padfSrcNoDataReal[i] = 500.;
psWO->padfSrcNoDataImag[i] = 0.0;
GDALSetRasterNoDataValue( GDALGetRasterBand(hDstDS, i+1), pdfDstNodata[0]);
and guess what? bloody zeros again. So I'm not able to get the NaNs (tried with 500 to see if this
solution works)
I tried to see what gdalwarp does ... and another problem. What is this?
gdalwarp -of netCDF -s_srs "+proj=latlong" -t_srs "+proj=utm +zone=29 +datum=WGS84" swath_grid.grd
lixo_utm.grd
Output driver `netCDF' not recognised or does not support
direct output file creation. The following format drivers are configured
and support direct output:
VRT: Virtual Raster
GTiff: GeoTIFF
NITF: National Imagery Transmission Format
HFA: Erdas Imagine Images (.img)
ELAS: ELAS
MEM: In Memory Raster
BMP: MS Windows Device Independent Bitmap
PCIDSK: PCIDSK Database File
ILWIS: ILWIS Raster Map
SGI: SGI Image File Format 1.0
Leveller: Leveller heightfield
Terragen: Terragen heightfield
HDF4Image: HDF4 Dataset
ERS: ERMapper .ers Labelled
JP2ECW: ERMapper JPEG2000
RMF: Raster Matrix Format
RST: Idrisi Raster A.1
INGR: Intergraph Raster
GSBG: Golden Software Binary Grid (.grd)
PNM: Portable Pixmap Format (netpbm)
ENVI: ENVI .hdr Labelled
EHdr: ESRI .hdr Labelled
PAux: PCI .aux Labelled
MFF: Vexcel MFF Raster
MFF2: Vexcel MFF2 (HKV) Raster
BT: VTP .bt (Binary Terrain) 1.3 Format
IDA: Image Data and Analysis
ADRG: ARC Digitized Raster Graphics
SAGA: SAGA GIS Binary Grid (.sdat)
I surely have the netCDF driver. The swath_grid.grd file is in netCDF and the above command works
for the default output type (GeoTiff).
Furthermore, if I ask for the drivers I have (I'm using FWTools here)
gdalwarp --formats
Supported Formats:
VRT (rw+): Virtual Raster
GTiff (rw+v): GeoTIFF
NITF (rw+v): National Imagery Transmission Format
RPFTOC (ro): Raster Product Format TOC format
HFA (rw+v): Erdas Imagine Images (.img)
SAR_CEOS (ro): CEOS SAR Image
CEOS (ro): CEOS Image
JAXAPALSAR (ro): JAXA PALSAR Product Reader (Level 1.1/1.5)
GFF (rov): Ground-based SAR Applications Testbed File Format (.gff)
ELAS (rw+): ELAS
AIG (ro): Arc/Info Binary Grid
AAIGrid (rwv): Arc/Info ASCII Grid
SDTS (ro): SDTS Raster
OGDI (ro): OGDI Bridge
DTED (rwv): DTED Elevation Raster
PNG (rwv): Portable Network Graphics
JPEG (rwv): JPEG JFIF
MEM (rw+): In Memory Raster
JDEM (ro): Japanese DEM (.mem)
GIF (rwv): Graphics Interchange Format (.gif)
BIGGIF (rov): Graphics Interchange Format (.gif)
ESAT (ro): Envisat Image Format
BSB (ro): Maptech BSB Nautical Charts
XPM (rw): X11 PixMap Format
BMP (rw+v): MS Windows Device Independent Bitmap
DIMAP (ro): SPOT DIMAP
AirSAR (ro): AirSAR Polarimetric Image
RS2 (ro): RadarSat 2 XML Product
PCIDSK (rw+v): PCIDSK Database File
PCRaster (rw): PCRaster Raster File
ILWIS (rw+v): ILWIS Raster Map
SGI (rw+): SGI Image File Format 1.0
SRTMHGT (rwv): SRTMHGT File Format
Leveller (rw+): Leveller heightfield
Terragen (rw+): Terragen heightfield
GMT (rw): GMT NetCDF Grid Format
netCDF (rw): Network Common Data Format
HDF4 (ro): Hierarchical Data Format Release 4
HDF4Image (rw+): HDF4 Dataset
ISIS3 (ro): USGS Astrogeology ISIS cube (Version 3)
ISIS2 (ro): USGS Astrogeology ISIS cube (Version 2)
PDS (ro): NASA Planetary Data System
TIL (ro): EarthWatch .TIL
ERS (rw+): ERMapper .ers Labelled
ECW (rw): ERMapper Compressed Wavelets
JP2ECW (rw+): ERMapper JPEG2000
L1B (ro): NOAA Polar Orbiter Level 1b Data Set
FIT (rw): FIT Image
GRIB (ro): GRIdded Binary (.grb)
MrSID (ro): Multi-resolution Seamless Image Database (MrSID)
JP2MrSID (ro): MrSID JPEG2000
RMF (rw+): Raster Matrix Format
WCS (ro): OGC Web Coverage Service
WMS (ro): OGC Web Map Service
MSGN (ro): EUMETSAT Archive native (.nat)
RST (rw+): Idrisi Raster A.1
INGR (rw+): Intergraph Raster
GSAG (rw): Golden Software ASCII Grid (.grd)
GSBG (rw+): Golden Software Binary Grid (.grd)
GS7BG (ro): Golden Software 7 Binary Grid (.grd)
COSAR (ro): COSAR Annotated Binary Matrix (TerraSAR-X)
TSX (ro): TerraSAR-X Product
COASP (ro): DRDC COASP SAR Processor Raster
R (rwv): R Object Data Store
PNM (rw+): Portable Pixmap Format (netpbm)
DOQ1 (ro): USGS DOQ (Old Style)
DOQ2 (ro): USGS DOQ (New Style)
ENVI (rw+v): ENVI .hdr Labelled
EHdr (rw+v): ESRI .hdr Labelled
GenBin (ro): Generic Binary (.hdr Labelled)
PAux (rw+): PCI .aux Labelled
MFF (rw+): Vexcel MFF Raster
MFF2 (rw+): Vexcel MFF2 (HKV) Raster
FujiBAS (ro): Fuji BAS Scanner Image
GSC (ro): GSC Geogrid
FAST (ro): EOSAT FAST Format
BT (rw+): VTP .bt (Binary Terrain) 1.3 Format
LAN (ro): Erdas .LAN/.GIS
CPG (ro): Convair PolGASP
IDA (rw+): Image Data and Analysis
NDF (ro): NLAPS Data Format
EIR (ro): Erdas Imagine Raw
DIPEx (ro): DIPEx
LCP (rov): FARSITE v.4 Landscape File (.lcp)
RIK (ro): Swedish Grid RIK (.rik)
USGSDEM (rw): USGS Optional ASCII DEM (and CDED)
GXF (ro): GeoSoft Grid Exchange Format
HTTP (ro): HTTP Fetching Wrapper
BAG (ro): Bathymetry Attributed Grid
HDF5 (ro): Hierarchical Data Format Release 5
HDF5Image (ro): HDF5 Dataset
NWT_GRD (ro): Northwood Numeric Grid Format .grd/.tab
NWT_GRC (ro): Northwood Classified Grid Format .grc/.tab
ADRG (rw+v): ARC Digitized Raster Graphics
SRP (rov): Standard Raster Product (ASRP/USRP)
BLX (rw): Magellan topo (.blx)
Rasterlite (rw): Rasterlite
WKTRaster (ro): PostGIS WKT Raster driver
SAGA (rw+v): SAGA GIS Binary Grid (.sdat)
> Joaquim,
> I believe what you see is the expected behaviour.
> You must keep in mind that there are 2 notions :
> 1) nodata value --> setting it is no more than just setting a "tag" on the
> raster band. It doesn't change the pixel values by itself as Chaintanya
> explained
> 2) initialization of the pixel data of the target image with a given value
> When you use the -dstnodata option, gdalwarp will automagically do both :
> 1) Set the target nodata value
> 2) Initialize the target image with that nodata value (remind of removing the
> target file if it already exists)
> If you specify nothing, then 0 is used to fill the target image but the nodata
> tag is not set.
> The initialization of the pixel data of the target image is in fact done
> through the INIT_DEST warping option. See
> http://gdal.org/structGDALWarpOptions.html#0ed77f9917bb96c7a9aabd73d4d06e08
> For example, gdalwarp src.tif dst.tif -wo "INIT_DEST=255"
> If you specify no INIT_DEST warping option, then gdalwarp uses the dstnodata
> value if it's specified with -dstnodata and set it as the INIT_DEST value
> too.
> I've also tested -dstnodata nan and to my great surprise, it actually works !
> However I'm not sure if all applications can deal with the "nan" string put
> in the 42113 tag used by GDAL for the Nodata value in TIFF.
> So maybe I've not understood what your problem is, but everything seems to
> work as expected on my side.
> Best regards,
> Even
> Le Wednesday 12 May 2010 01:37:07 Joaquim Luis, vous avez écrit :
>> Hi,
>> Before filling a ticket I would like to ask here if this gdalwarp
>> behavior is the intended one.
>> When I convert a grid from geogs to UTM the nodatavalues are filled with
>> zeros.
>> I get the expected behaviour if I use the -dstnodata with a numeric
>> value, but I found no way tom tell it use NaN.
>> Summary
>> This puts zeros on the nodata zone, but I don't find it correct as "0"
>> is not exactly a natural nodata value. For my habits NaN is the natural
>> no data value.
>> gdalwarp -s_srs "+proj=latlong" -t_srs "+proj=utm +zone=29 +datum=WGS84"
>> swath_grid.grd lixo_utm.tiff
>> Furthermore when I load the " lixo_utm.tiff" in Mirone is does not
>> recognize a nodata value, whilst if I do this instead
>> -dstnodata 1 swath_grid.grd lixo_utm.tiff
>> than "1" is recognized as the nodata. I have not investigated the
>> metadata to see why the "0" is not set to represent the nodata.
>> Thanks
>> Joaquim Luis
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
