[gdal-dev] Re: srs definition for wgs84
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Thu May 13 09:52:23 EDT 2010
I believe that Imran is willing to use Oracle data, once they are in, through Geoserver. On the other hand, I do not believe that Geoserver supports those Oracle SRIDs but it wants to see SRID=4326 for WGS84 data in Oracle. Therefore even the Oracle codes may be better in some way in this case they could be unusable. I have not tried ever with SRID=4326 in Oracle, but using SRID=2393 in Oracle works fine together with our EPSG:2393 data and Geoserver.
-Jukka-
-----Alkuperäinen viesti-----
Lähettäjä: Peter J Halls [mailto:P.Halls at york.ac.uk]
Lähetetty: to 13.5.2010 16:02
Vastaanottaja: Rahkonen Jukka
Kopio: gdal-dev at lists.osgeo.org
Aihe: Re: [gdal-dev] Re: srs definition for wgs84
Jukka,
Jukka Rahkonen wrote:
> Peter J Halls <P.Halls <at> york.ac.uk> writes:
>> Imran,
>>     the Oracle SRID value of 8192 *is* WGS84.  Oracle does not store the EPSG
>> values, but has its own set.
> Starting from Oracle 10g or something it supports also EPSG codes. Old codes are
> still supported by Oracle but other programs usually do not understand Oracle
> SRID codes. Fortunately they are no more needed. But I think that the correct
    from the (11g) Oracle Spatial reference manual:
"The Oracle Spatial coordinate system support is based on, but is not always
identical to, the European Petroleum Survey Group (EPSG) data model and dataset."
Methods are provided to express the Oracle SRID as EPSG WKT and to translate
between Oracle SRID values and EPSG values.  These are needed for programs which
do not understand the Oracle SRID values.
This means that, without care, Oracle reports will specify the Oracle SRID
values, which are those stored and used internally, rather than the EPSG values.
  Oracle also supports projections additional to the EPSG schema.  This seems to
be what Imran saw.
Yes, this change was introduced at 10g and replaced something rather different
(and which I have never used), but the current system does not simply use EPSG
as you imply.
> way to give target SRID with ogr Oracle driver is not to use -a_srs but the
> Layer Creation Option -lco SRID=4326.
Agreed, although up to and including GDAL 1.6.n I have failed to get this method
to work when using the API.  The problem is more than likely something I've done
wrong and I have not yet tried 1.7.n.
Best wishes,
Peter
> -Jukka Rahkonen-
> gdal-dev mailing list
Peter J Halls, GIS Advisor, University of York
Telephone: 01904 433806     Fax: 01904 433740
Snail mail: Computing Service, University of York, Heslington, York YO10 5DD
This message has the status of a private and personal communication
