[gdal-dev] gdalwarp's default nodata value
Even Rouault
even.rouault at mines-paris.org
Thu May 13 13:38:57 EDT 2010
Joaquim,
> For the rec, VS2010 and a quite recent trunk version.
Ah, this is the reason for the different results we got. On Windows,
atof("nan") returns 0... but on Linux it returns a nan number.
I've pushed quite a few changes to trunk to improve the situation on Windows
and other changes for all platforms to fix the case when we compare pixel
values to nodata value and the nodata value is nan. Indeed, the test "value
== dfNoDataValue" that was generally used fails if value == nan and
dfNoDataValue == nan, because nan != nan...
See http://trac.osgeo.org/gdal/ticket/3576
Best regards,
Even
