[gdal-dev] Re: how to get the each pixel value from the dataset
    Kyle Shannon
    ksshannon at gmail.com
    Thu May 20 00:10:40 EDT 2010
As I am not familiar with .net, i assume it is similar to c++.  You can find
the info under "Reading Raster Data" on this page:
http://www.gdal.org/gdal_tutorial.html .
kss
On Wed, May 19, 2010 at 10:02 PM, mail2vajram <mail2vajram at gmail.com> wrote:
> Thanks mr.Frank
> I am using .NET API.My query is
> When we assign a TIFF image to DATASET, then we get RASTERXSIZE and
> RASTERYSIZE.
> Here i am trying to GET each pixel value(brightness value) using two for
> loops.But i don't know which method is used to get this values.
> Thank you......
> http://osgeo-org.1803224.n2.nabble.com/how-to-get-the-each-pixel-value-from-the-dataset-tp5074085p5078085.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100519/a8760898/attachment.html
