[gdal-dev] How to read first line pixel values of an image into buffer
Thu May 20 08:09:58 EDT 2010
mail2vajram wrote:
> I am using the following code to read pixel values. It read only one pixel
> value..how to read entire row..
> generally this code is used to read 0th column 1st row and return pixel
> value into buffer.
> code:
>  Band band = ds.GetRasterBand(1);
>  double[] buffer = new double[ds.RasterXSize];
>  band.ReadRaster(0, 1,1,1, buffer, 1,1, 1, 1);
> but when i am using the following code i am not able to getting entire first
> row values values.
> band.ReadRaster(0, 1,ds.RasterXSize,1, buffer, 1, 1, 1, 1);
> Can any body suggest me which parameter i need to change. Iam using C# code
Vajram,
band.ReadRaster(0,1,ds.RasterXSize,1, buffer, ds.RasterXSize, 1, 1, 1 )
Note that your yoffset (second parameter) is 1, so you are really
reading the second line.
Best regards,
