[gdal-dev] NITF 2.1 GDAL 1.7.2 and FWTools 2.4.7 Translation Errors
Doug White
doug.royce.white at gmail.com
Fri May 21 01:35:38 EDT 2010
I have been trying to translate a DigitalGlobe GeoEye-1 NITF image to
GeoTiff or JP2 with GDAL 1.7.2 compiled with JP2ECW on x86 Linux and
also with FWTools 2.4.7 (raises a unknown software exception).
gdalinfo will read the file successfully. I can display the file with
PCI Geomatics on a Windows platform.
However we consistently get a seg-fault on attempts to translate a
number of NITF images. It doesn't seem to matter what creation options
are used or what output format is chosen.
gdal_translate -of gtiff -co COMPRESS=LZW -sds test1.ntf out.tif
Input file size is 35840, 27648
0...10...20...30...40...50...60...Segmentation fault
Output from gdalinfo is below along with supported formats.
Any assistance would be appreciate as I have potentially will have a
large number of similar images that must be transformed to either
GeoTiff or JP2 formats.
Regards,
Doug White.
gdalinfo test1.ntf
Driver: NITF/National Imagery Transmission Format
Files: test1.ntf
Size is 35840, 27648
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AUTHORITY["EPSG","4326"]]
GeoTransform =
151.8181220669296, 5.871164560022267e-06, -5.023651349735254e-09
-20.99465038292781, 8.719551326766783e-07, -5.661655072079407e-06
Metadata:
NITF_FHDR=NITF02.10
NITF_CLEVEL=06
NITF_STYPE=BF01
NITF_OSTAID=DG
NITF_FDT=20080105031559
NITF_FTITLE=WV01_SENSOR:2008-01-04T23:56:28.358625Z
NITF_FSCLAS=U
NITF_FSCLSY=US
NITF_FSCODE=
NITF_FSCTLH=0
NITF_FSREL=UNCLASSIFIED
NITF_USE00A_ANGLE_TO_NORTH=270
NITF_USE00A_MEAN_GSD=025.0
NITF_USE00A_DYNAMIC_RANGE=02047
NITF_USE00A_OBL_ANG=29.02
NITF_STDIDC_ACQUISITION_DATE=20080104235628
NITF_STDIDC_MISSION=WV01
NITF_STDIDC_PASS=16
NITF_STDIDC_OP_NUM=000
NITF_STDIDC_START_SEGMENT=AA
NITF_STDIDC_REPRO_NUM=00
NITF_STDIDC_REPLAY_REGEN=000
NITF_STDIDC_START_COLUMN=001
NITF_STDIDC_START_ROW=00001
NITF_STDIDC_END_SEGMENT=AA
NITF_STDIDC_END_COLUMN=035
NITF_STDIDC_END_ROW=00027
NITF_STDIDC_COUNTRY=YY
NITF_STDIDC_WAC=
NITF_STDIDC_LOCATION=2059S15155E
NITF_USE00A_ROLL_ANG=-19.90
NITF_USE00A_N_REF=00
NITF_USE00A_REV_NUM=01648
NITF_USE00A_N_SEG=001
NITF_USE00A_MAX_LP_SEG=027024
NITF_USE00A_SUN_EL=+62.0
NITF_USE00A_SUN_AZ=099.3
NITF_FSDCTP=
NITF_FSDCDT=
NITF_FSDCXM=
NITF_FSDG=
NITF_FSDGDT=
NITF_FSCLTX=
NITF_FSCATP=
NITF_FSCAUT=
NITF_FSCRSN=
NITF_FSSRDT=
NITF_FSCTLN=
NITF_FSCOP=00000
NITF_FSCPYS=00000
NITF_ENCRYP=0
NITF_FBKGC=126,126,126
NITF_ONAME=DigitalGlobe
NITF_OPHONE=+1(800)496-1225
NITF_IID1=P101B5EB00
NITF_IDATIM=20080104235628
NITF_TGTID=
NITF_IID2=04JAN08WV011600008JAN04235628-P1BS-005692925010_02_P001
NITF_ISCLAS=U
NITF_ISCLSY=US
NITF_ISCODE=
NITF_ISCTLH=0
NITF_ISREL=UNCLASSIFIED
NITF_ISDCTP=
NITF_ISDCDT=
NITF_ISDCXM=
NITF_ISDG=
NITF_ISDGDT=
NITF_ISCLTX=
NITF_ISCATP=
NITF_ISCAUT=
NITF_ISCRSN=
NITF_ISSRDT=
NITF_ISCTLN=
NITF_ISORCE=DigitalGlobe
NITF_PVTYPE=INT
NITF_IREP=MONO
NITF_ICAT=VIS
NITF_ABPP=11
NITF_PJUST=R
NITF_IMAGE_COMMENTS=The imagery and metadata data on this media is
the property of DigitalGlobe and is licensed for use
only. All use must be in accordance with the terms of
the license that accompanies the media. If the license is
purchased under contract NMA 301 99 D003, use is in
accordance with the license therein
NITF_IC=C8
NITF_IMODE=B
NITF_IDLVL=1
NITF_IALVL=0
NITF_ILOC_ROW=0
NITF_ILOC_COLUMN=0
NITF_CCS_ROW=0
NITF_CCS_COLUMN=0
NITF_IMAG=1.0
Image Structure Metadata:
COMPRESSION=JPEG2000
Subdatasets:
SUBDATASET_1_NAME=NITF_IM:0:test1.ntf
SUBDATASET_1_DESC=Image 1 of test1.ntf
SUBDATASET_2_NAME=NITF_IM:1:test1.ntf
SUBDATASET_2_DESC=Image 2 of test1.ntf
RPC Metadata:
LINE_OFF=13513
LINE_SCALE=13856
SAMP_OFF=17568
SAMP_SCALE=17880
LONG_OFF=151.9233
LONG_SCALE=0.1053
LAT_OFF=-21.0572
LAT_SCALE=0.094
HEIGHT_OFF=56
HEIGHT_SCALE=500
LINE_NUM_COEFF=-0.0004377388 0.1957893 -1.171648 0.02476541
0.0004988891 1.071111e-06 -7.723183e-05 -0.0001365399 0.0001504459
-3.044538e-07 -5.480692e-07 2.582038e-06 2.00101e-05 3.445864e-06
-1.734241e-05 -7.362311e-05 -2.064705e-05 3.295859e-07 3.97851e-06
2.958957e-07
LINE_DEN_COEFF=1 0.0006958351 -0.0004343016 -7.94123e-05 3.205817e-05
-6.129374e-07 2.904883e-06 1.144677e-05 -6.601517e-05 1.76217e-05
2.432827e-07 1.147129e-07 3.2925e-07 3.846231e-08 -8.681516e-07
9.004578e-06 -1.561498e-07 0 -1.282879e-06 3.197183e-07
SAMP_NUM_COEFF=-0.005897845 0.9845455 -0.0008736188 -0.01633278
-0.0005572224 0.0004192778 -0.0001797468 0.006762 3.550668e-05
-2.729457e-06 -2.47284e-06 2.339311e-05 -1.283381e-05 -5.962048e-06
4.604063e-05 8.796591e-06 1.358451e-08 5.049965e-06 -1.806894e-08 0
SAMP_DEN_COEFF=1 -0.0008445728 0.000539573 -0.0005092088
-3.422971e-05 -3.243685e-06 1.062892e-06 5.948981e-06 1.065874e-05
-6.439563e-06 -5.457996e-08 0 -3.445098e-07 3.646394e-08 -7.223879e-07
1.128396e-06 0 -3.12891e-08 -4.239271e-08 0
MIN_LONG=151.87065
MAX_LONG=151.97595
MIN_LAT=-21.1042
MAX_LAT=-21.0102
Corner Coordinates:
Upper Left ( 151.8181221, -20.9946504) (151d49'5.24"E, 20d59'40.74"S)
Lower Left ( 151.8179832, -21.1511838) (151d49'4.74"E, 21d 9'4.26"S)
Upper Right ( 152.0285446, -20.9633995) (152d 1'42.76"E, 20d57'48.24"S)
Lower Right ( 152.0284057, -21.1199330) (152d 1'42.26"E, 21d 7'11.76"S)
Center ( 151.9232639, -21.0572917) (151d55'23.75"E, 21d 3'26.25"S)
Band 1 Block=35840x1 Type=UInt16, ColorInterp=Gray
Overviews: arbitrary
gdal_translate --formats
Supported Formats:
VRT (rw+): Virtual Raster
GTiff (rw+v): GeoTIFF
NITF (rw+v): National Imagery Transmission Format
RPFTOC (ro): Raster Product Format TOC format
HFA (rw+v): Erdas Imagine Images (.img)
SAR_CEOS (ro): CEOS SAR Image
CEOS (ro): CEOS Image
JAXAPALSAR (ro): JAXA PALSAR Product Reader (Level 1.1/1.5)
GFF (rov): Ground-based SAR Applications Testbed File Format (.gff)
ELAS (rw+): ELAS
AIG (ro): Arc/Info Binary Grid
AAIGrid (rwv): Arc/Info ASCII Grid
SDTS (ro): SDTS Raster
OGDI (ro): OGDI Bridge
DTED (rwv): DTED Elevation Raster
PNG (rwv): Portable Network Graphics
JPEG (rwv): JPEG JFIF
MEM (rw+): In Memory Raster
JDEM (ro): Japanese DEM (.mem)
GIF (rwv): Graphics Interchange Format (.gif)
BIGGIF (rov): Graphics Interchange Format (.gif)
ESAT (ro): Envisat Image Format
FITS (rw+): Flexible Image Transport System
BSB (ro): Maptech BSB Nautical Charts
XPM (rw): X11 PixMap Format
BMP (rw+v): MS Windows Device Independent Bitmap
DIMAP (ro): SPOT DIMAP
AirSAR (ro): AirSAR Polarimetric Image
RS2 (ro): RadarSat 2 XML Product
PCIDSK (rw+v): PCIDSK Database File
PCRaster (rw): PCRaster Raster File
ILWIS (rw+v): ILWIS Raster Map
SGI (rw+): SGI Image File Format 1.0
SRTMHGT (rwv): SRTMHGT File Format
Leveller (rw+): Leveller heightfield
Terragen (rw+): Terragen heightfield
GMT (rw): GMT NetCDF Grid Format
netCDF (rw): Network Common Data Format
HDF4 (ro): Hierarchical Data Format Release 4
HDF4Image (rw+): HDF4 Dataset
ISIS3 (ro): USGS Astrogeology ISIS cube (Version 3)
ISIS2 (ro): USGS Astrogeology ISIS cube (Version 2)
PDS (ro): NASA Planetary Data System
TIL (ro): EarthWatch .TIL
ERS (rw+): ERMapper .ers Labelled
ECW (rw): ERMapper Compressed Wavelets
JP2ECW (rw+): ERMapper JPEG2000
JPEG2000 (rwv): JPEG-2000 part 1 (ISO/IEC 15444-1)
L1B (ro): NOAA Polar Orbiter Level 1b Data Set
FIT (rw): FIT Image
GRIB (ro): GRIdded Binary (.grb)
MrSID (ro): Multi-resolution Seamless Image Database (MrSID)
RMF (rw+): Raster Matrix Format
WCS (ro): OGC Web Coverage Service
WMS (ro): OGC Web Map Service
MSGN (ro): EUMETSAT Archive native (.nat)
RST (rw+): Idrisi Raster A.1
INGR (rw+): Intergraph Raster
GSAG (rw): Golden Software ASCII Grid (.grd)
GSBG (rw+): Golden Software Binary Grid (.grd)
GS7BG (ro): Golden Software 7 Binary Grid (.grd)
COSAR (ro): COSAR Annotated Binary Matrix (TerraSAR-X)
TSX (ro): TerraSAR-X Product
COASP (ro): DRDC COASP SAR Processor Raster
R (rwv): R Object Data Store
PNM (rw+): Portable Pixmap Format (netpbm)
DOQ1 (ro): USGS DOQ (Old Style)
DOQ2 (ro): USGS DOQ (New Style)
ENVI (rw+v): ENVI .hdr Labelled
EHdr (rw+v): ESRI .hdr Labelled
GenBin (ro): Generic Binary (.hdr Labelled)
PAux (rw+): PCI .aux Labelled
MFF (rw+): Vexcel MFF Raster
MFF2 (rw+): Vexcel MFF2 (HKV) Raster
FujiBAS (ro): Fuji BAS Scanner Image
GSC (ro): GSC Geogrid
FAST (ro): EOSAT FAST Format
BT (rw+): VTP .bt (Binary Terrain) 1.3 Format
LAN (ro): Erdas .LAN/.GIS
CPG (ro): Convair PolGASP
IDA (rw+): Image Data and Analysis
NDF (ro): NLAPS Data Format
EIR (ro): Erdas Imagine Raw
DIPEx (ro): DIPEx
LCP (rov): FARSITE v.4 Landscape File (.lcp)
RIK (ro): Swedish Grid RIK (.rik)
USGSDEM (rw): USGS Optional ASCII DEM (and CDED)
GXF (ro): GeoSoft Grid Exchange Format
HTTP (ro): HTTP Fetching Wrapper
BAG (ro): Bathymetry Attributed Grid
HDF5 (ro): Hierarchical Data Format Release 5
HDF5Image (ro): HDF5 Dataset
NWT_GRD (ro): Northwood Numeric Grid Format .grd/.tab
NWT_GRC (ro): Northwood Classified Grid Format .grc/.tab
ADRG (rw+v): ARC Digitized Raster Graphics
SRP (rov): Standard Raster Product (ASRP/USRP)
BLX (rw): Magellan topo (.blx)
Rasterlite (rw): Rasterlite
WKTRaster (ro): PostGIS WKT Raster driver
SAGA (rw+v): SAGA GIS Binary Grid (.sdat)
