[gdal-dev] Re: gdal_retile and nodata
acangi
aca at ngi.be
Fri May 21 09:27:59 EDT 2010
After removing the GDAL_PAM_ENABLED=NO, I made a
gdal_translate -a_nodata 0
on the files, this generated the aux.xml files, and gdalinfo shows now the
nodata values :
Band 1 Block=4000x16 Type=Byte, ColorInterp=Red
NoData Value=0
Band 2 Block=4000x16 Type=Byte, ColorInterp=Green
NoData Value=0
Band 3 Block=4000x16 Type=Byte, ColorInterp=Blue
NoData Value=0
gdal_retile is currently running, but it doesn't produce aux.xml files.
gdalinfo doesn't show any nodata value on the files generated by
gdal_retile. So I guess when the next level will start computing, the same
problem will reproduce. I should see the result monday.
Alain
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-retile-and-nodata-tp5079895p5084204.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
