[gdal-dev] Re: gdal_retile and nodata
christian.mueller at nvoe.at
Fri May 21 10:38:03 EDT 2010
Any new tile is created according to the create options "-co
Name=value" you can pass in as parameter.
First an image is created, larege enough to hold the tile and its
neighbors from level x-1
Second , the tiles from level x-1 are painted onto this image.
Third, the scaling takes place.
Fourth, I crop the interesting part for level x
The problem is, sometimes neighbors are missing, right ?
Do you have this problem already at level 1 or beginning with level 2 ?
Do you start from one big image or an already tiled image ?
Quoting acangi <aca at ngi.be>:
> I ran gdal_retile on a smaller set of data (same data with nodata values) so
> I already have a result. You can see the border on the picture. In GeoServer
> I set the outputTransparentColor to #000000.
> I don't think my problem comes from the existing nodata values in the source
> files, but rather from non-existing tiles at level x-1, when generating
> level x. There is a gap at level x-1 and gdal_retile has to write data at
> level x. What data is it supposed to write when there is no tile covering
> this location at level x-1 ?
> http://n2.nabble.com/file/n5084464/nearblack_border.png
> http://osgeo-org.1803224.n2.nabble.com/gdal-retile-and-nodata-tp5079895p5084464.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
This message was sent using IMP, the Internet Messaging Program.
