[gdal-dev] Gdalwarp of GLOBCOVER to UTMSpecific Zone
Luisa Peña
luisapena1979 at gmail.com
Mon May 24 13:10:59 EDT 2010
Hi there
I'm a bit of a newbie in GDAL but I tried to warp a GLOBCOVER image with
this information:
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Into an UTM zone (EPSG:21036)
I runned this command:
gdalwarp -t_srs "EPSG:21036" INPUT.tif OUTPUT.tif
And I get this Warning/ERROR:
ERROR 1: TIFFFetchDirectory:MZ.tif: Can not read TIFF directory count
ERROR 1: TIFFReadDirectory:Failed to read directory at offset 8
ERROR 1: TIFFWriteEncodedStrip:Must set "ImageWidth" before writing data
Segmentation fault
And I obtained an OUTPUT.tif with a different size.
- What might not be ok in this?
- What can I do to obtain an image with the same size?
Thanks
best regards
Luisa
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100524/311d3eba/attachment.html
