Re: [gdal-dev] Can't read HDF4 - TRMM
    Ivan Lucena
    ivan.lucena at pmldnet.com
    Mon May 24 14:51:19 EDT 2010
Hi Joaquim,
It seems to me that the HDF4 driver is taking the liberty of using the EOS API to read that file that is actually in HDF format, more specifically a SD (Scientific Dataset).
http://trac.osgeo.org/gdal/browser/trunk/gdal/frmts/hdf4/hdf4dataset.cpp#L762
That is why it doesn't go to that call to SDfileinfo():
http://trac.osgeo.org/gdal/browser/trunk/gdal/frmts/hdf4/hdf4dataset.cpp#L991
If change poDS->bIsHDFEOS to 0 in debugging mode and the subdatasets showed up:
Driver: HDF4/Hierarchical Data Format Release 4
Files: 3B430501016.HDF
Size is 512, 512
Coordinate System is `'
Subdatasets:
  SUBDATASET_1_NAME=HDF4_SDS:UNKNOWN:"3B430501016.HDF":0
  SUBDATASET_1_DESC=[1x1440x400] precipitation (32-bit floating-point)
  SUBDATASET_2_NAME=HDF4_SDS:UNKNOWN:"3B430501016.HDF":1
  SUBDATASET_2_DESC=[1x1440x400] relativeError (32-bit floating-point)
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,  512.0)
Upper Right (  512.0,    0.0)
Lower Right (  512.0,  512.0)
Center      (  256.0,  256.0)
Now I can gdal_translate it to GTIFF but the image comes rotated by 90 degrees just like in other software.
I think we can file a ticket to deal with the miss identification, at least.
Obrigado pela dica.
Thanks for the tip,
Ivan
>  -------Original Message-------
>  From: Joaquim Luis <jluis at ualg.pt>
>  To: Ivan Lucena <ivan.lucena at pmldnet.com>
>  Cc: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
>  Subject: Re: [gdal-dev] Can't read HDF4 - TRMM
>  Sent: May 24 '10 10:46
>  Ivan,
>  Since nasa is now imitating me (http://mirador....) I gave it a shot
>  with Mirone, which obviously also failed because because it relies
>  mostly in gdal to read the hdf files.
>  My experience with the nasa satellite files is that they are a big mess
>  with the metadata written in endless different ways which makes the
>  parsing very painful. There is some reference info in the files. See
>  what I got using Matlab (look at the end of this long list)
>  Joaquim
>  >>  info.Attributes(1).Value
>  ans =
>  OBJECT=OrbitNumber;
>  Value=-9999;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=OrbitNumber;
>  OBJECT=RangeBeginningDate;
>  Value=2010/04/01;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=RangeBeginningDate;
>  OBJECT=RangeBeginningTime;
>  Value=00:00:00;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=RangeBeginningTime;
>  OBJECT=RangeEndingDate;
>  Value=2010/05/01;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=RangeEndingDate;
>  OBJECT=RangeEndingTime;
>  Value=00:00:00;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=RangeEndingTime;
>  OBJECT=GranulePointer;
>  Value="3B43.100401.6A.HDF";
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=GranulePointer;
>  OBJECT=ShortName;
>  Value="Surface Rain from all Satellite and Surface";
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=ShortName;
>  OBJECT=SizeMBECSDataGranule;
>  Value=4.394;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=SizeMBECSDataGranule;
>  OBJECT=LongitudeOfMaximumLatitude;
>  Value=-9999.9;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=LongitudeOfMaximumLatitude;
>  OBJECT=SpatialCoverageType;
>  Value="Horizontal";
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=SpatialCoverageType;
>  OBJECT=EllipsoidName;
>  Value="NULL";
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=EllipsoidName;
>  OBJECT=EquatorialRadius;
>  Value=-9999.9;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=EquatorialRadius;
>  OBJECT=DenominatorFlatteningRatio;
>  Value=-9999.9;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=DenominatorFlatteningRatio;
>  OBJECT=OrbitalModelName;
>  Value="NULL";
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=OrbitalModelName;
>  OBJECT=SemiMajorAxis;
>  Value=-9999.9;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=SemiMajorAxis;
>  OBJECT=MeanAnomaly;
>  Value=-9999.9;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=MeanAnomaly;
>  OBJECT=RightAscensionNode;
>  Value=-9999.9;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=RightAscensionNode;
>  OBJECT=ArgumentOfPerigee;
>  Value=-9999.9;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=ArgumentOfPerigee;
>  OBJECT=Eccentricity;
>  Value=-9999.9;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=Eccentricity;
>  OBJECT=Inclination;
>  Value=-9999.9;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=Inclination;
>  OBJECT=EpochTime;
>  Value=99:99:99;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=EpochTime;
>  OBJECT=EpochDate;
>  Value=9999/99/99;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=EpochDate;
>  OBJECT=EpochMillisec;
>  Value=-9999.9;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=EpochMillisec;
>  OBJECT=WestBoundingCoordinate;
>  Value=-180;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=WestBoundingCoordinate;
>  OBJECT=EastBoundingCoordinate;
>  Value=180;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=EastBoundingCoordinate;
>  OBJECT=NorthBoundingCoordinate;
>  Value=50;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=NorthBoundingCoordinate;
>  OBJECT=SouthBoundingCoordinate;
>  Value=-50;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=SouthBoundingCoordinate;
>  OBJECT=CenterLatitude;
>  Value=-9999.9;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=CenterLatitude;
>  OBJECT=CenterLongitude;
>  Value=-9999.9;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=CenterLongitude;
>  OBJECT=RadiusValue;
>  Value=-9999.9;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=RadiusValue;
>  OBJECT=LatitudeResolution;
>  Value=".25deg";
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=LatitudeResolution;
>  OBJECT=LongitudeResolution;
>  Value=".25deg";
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=LongitudeResolution;
>  OBJECT=GeographicCoordinateUnits;
>  Value="Decimal Degrees";
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=GeographicCoordinateUnits;
>  OBJECT=TemporalRangeType;
>  Value="Continuous Range";
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=TemporalRangeType;
>  OBJECT=QualityAssuranceParameterName;
>  Value="ScienceQualityFlag";
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=QualityAssuranceParameterName;
>  OBJECT=QualityAssuranceParameterValue;
>  Value="NOT BEING INVESTIGATED";
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=QualityAssuranceParameterValue;
>  OBJECT=ReprocessingActual;
>  Value="NULL";
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=ReprocessingActual;
>  OBJECT=BrowsePointer;
>  Value="3B43_BR.100401.6A.PNG";
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=BrowsePointer;
>  OBJECT=ScienceContact;
>  Value="George Huffman";
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=ScienceContact;
>  OBJECT=MeanMotion;
>  Value=-9999.9;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=MeanMotion;
>  OBJECT=OrbitAdjustFlag;
>  Value=-9999;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=OrbitAdjustFlag;
>  OBJECT=AttitudeModeFlag;
>  Value=-9999;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=AttitudeModeFlag;
>  OBJECT=SolarBetaAngleAtBeginningOfGranule;
>  Value=-9999.9;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=SolarBetaAngleAtBeginningOfGranule;
>  OBJECT=SolarBetaAngleAtEndOfGranule;
>  Value=-9999.9;
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=SolarBetaAngleAtEndOfGranule;
>  OBJECT=SensorAlignment;
>  Value="NULL";
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=SensorAlignment;
>  OBJECT=SensorAlignmentChannelOffsets;
>  Value="NULL";
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=SensorAlignmentChannelOffsets;
>  OBJECT=ScanPathModel;
>  Value="NULL";
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=ScanPathModel;
>  OBJECT=ScanPathModelParam;
>  Value="NULL";
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=ScanPathModelParam;
>  OBJECT=EphemerisFileID;
>  Value="NULL";
>  Data_Location=PGE;
>  Mandatory=FALSE;
>  END_OBJECT=EphemerisFileID;
>  > Hi,
>  > I ran gdalinfo on some HDF4 files and no subdataset shows up.
>  > The data is available for download at this website: http://mirador.gsfc.nasa.gov/cgi-bin/mirador/presentNavigation.pl?tree=project&project=TRMM&dataGroup=Gridded&dataset=3B43:%20Monthly%200.25%20x%200.25%20degree%20merged%20TRMM%20and%20other%20sources%20estimates&version=006
>  > I tried reading those some file on:
>  > - Idrisi
>  > - ArcGIS 9.3
>  > - ArcGIS 10 (RC)
>  > - Erdas
>  > They do identify the internal datasets but they cannot identify the reference system and the images they are flipped by 90' clockwise. But that is not due to rotation. I would guess. It is more like a misinterpretation of the dimension parameter, taking rows as columns and columns as rows.  It looks like the documentation for that particular product is missing here: http://mirador.gsfc.nasa.gov/cgi-bin/mirador/servcoll.pl?helpmenuclass=inventory&SearchButton=Search%20GES-DISC
>  > Does anybody has a clue?
>  > BTW. There is a netCDF version of that data that also has some issues.
>  > Regards,
>  > Ivan
>  > _______________________________________________
>  > gdal-dev mailing list
>  > gdal-dev at lists.osgeo.org
>  > http://lists.osgeo.org/mailman/listinfo/gdal-dev
