Re: [gdal-dev] Can't read HDF4 - TRMM
Ivan Lucena ivan.lucena at pmldnet.com
Tue May 25 11:41:25 EDT 2010
It look like pyHDF know more about the HDF SD dimensions than the other software, including GDAL:
>>> from pyhdf.SD import *
>>> d = SD('D:\\tmp\\3B430501016.HDF')
>>> d.datasets()
{'precipitation': (('scan', 'longitude', 'latitude'), (1, 1440, 400), 5, 0), 'relativeError': (('scan', 'longitude', 'latitude'), (1, 1440, 400), 5, 1)}
>>> ds = d.select('precipitation')
>>> ds.dimensions()
{'latitude': 400, 'longitude': 1440, 'scan': 1}
That means 1440 columns, 400 rows, and 1 band.
But GDAL, Idrisi, ArcGIS, Erdas and Envi reads it as 400 columns, 1440 rows, and 1 band.
D:\BugsJar>gdal_translate HDF4_SDS:UNKNOWN:"3B430501016.HDF":0 out.tif
Input file size is 400, 1440
0...10...20...30...40...50...60...70...80...90...100 - done.
$ gdalinfo out.tif
Driver: GTiff/GeoTIFF
Files: out.tif
Size is 400, 1440
Coordinate System is `'
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0, 1440.0)
Upper Right (  400.0,    0.0)
Lower Right (  400.0, 1440.0)
Center      (  200.0,  720.0)
Band 1 Block=400x5 Type=Float32, ColorInterp=Gray
There is something wrong with the internal documentation of that file but it seems to be possible to find the dimensions from other HDF (not EOS) API functions. I would try to include calls to SDdiminfo() or SDgetdimstr() perhaps.
Regards,
Ivan
>  -------Original Message-------
>  From: Ivan Lucena <ivan.lucena at pmldnet.com>
>  To: Joaquim Luis <jluis at ualg.pt>
>  Cc: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
>  Subject: Re: [gdal-dev] Can't read HDF4 - TRMM
>  Sent: May 24 '10 13:51
>  Hi Joaquim,
>  It seems to me that the HDF4 driver is taking the liberty of using the EOS API to read that file that is actually in HDF format, more specifically a SD (Scientific Dataset).
>  http://trac.osgeo.org/gdal/browser/trunk/gdal/frmts/hdf4/hdf4dataset.cpp#L762
>  That is why it doesn't go to that call to SDfileinfo():
>  http://trac.osgeo.org/gdal/browser/trunk/gdal/frmts/hdf4/hdf4dataset.cpp#L991
>  If change poDS->bIsHDFEOS to 0 in debugging mode and the subdatasets showed up:
>  Driver: HDF4/Hierarchical Data Format Release 4
>  Files: 3B430501016.HDF
>  Size is 512, 512
>  Subdatasets:
>    SUBDATASET_1_NAME=HDF4_SDS:UNKNOWN:"3B430501016.HDF":0
>    SUBDATASET_1_DESC=[1x1440x400] precipitation (32-bit floating-point)
>    SUBDATASET_2_NAME=HDF4_SDS:UNKNOWN:"3B430501016.HDF":1
>    SUBDATASET_2_DESC=[1x1440x400] relativeError (32-bit floating-point)
>  Corner Coordinates:
>  Lower Left  (    0.0,  512.0)
>  Upper Right (  512.0,    0.0)
>  Lower Right (  512.0,  512.0)
>  Center      (  256.0,  256.0)
>  Now I can gdal_translate it to GTIFF but the image comes rotated by 90 degrees just like in other software.
>  I think we can file a ticket to deal with the miss identification, at least.
>  Obrigado pela dica.
>  Thanks for the tip,
>  Ivan
>  >  -------Original Message-------
>  >  From: Joaquim Luis <jluis at ualg.pt>
>  >  To: Ivan Lucena <ivan.lucena at pmldnet.com>
>  >  Cc: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
>  >  Subject: Re: [gdal-dev] Can't read HDF4 - TRMM
>  >  Sent: May 24 '10 10:46
>  >  Ivan,
>  >  Since nasa is now imitating me (http://mirador....) I gave it a shot
>  >  with Mirone, which obviously also failed because because it relies
>  >  mostly in gdal to read the hdf files.
>  >  My experience with the nasa satellite files is that they are a big mess
>  >  with the metadata written in endless different ways which makes the
>  >  parsing very painful. There is some reference info in the files. See
>  >  what I got using Matlab (look at the end of this long list)
>  >  Joaquim
>  >  >>  info.Attributes(1).Value
>  >  ans =
>  >  OBJECT=OrbitNumber;
>  >  Value=-9999;
>  >  Data_Location=PGE;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=OrbitNumber;
>  >  OBJECT=RangeBeginningDate;
>  >  Value=2010/04/01;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=RangeBeginningDate;
>  >  OBJECT=RangeBeginningTime;
>  >  Value=00:00:00;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=RangeBeginningTime;
>  >  OBJECT=RangeEndingDate;
>  >  Value=2010/05/01;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=RangeEndingDate;
>  >  OBJECT=RangeEndingTime;
>  >  Value=00:00:00;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=RangeEndingTime;
>  >  OBJECT=GranulePointer;
>  >  Value="3B43.100401.6A.HDF";
>  >  Mandatory=FALSE;
>  >  END_OBJECT=GranulePointer;
>  >  OBJECT=ShortName;
>  >  Value="Surface Rain from all Satellite and Surface";
>  >  Mandatory=FALSE;
>  >  END_OBJECT=ShortName;
>  >  OBJECT=SizeMBECSDataGranule;
>  >  Value=4.394;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=SizeMBECSDataGranule;
>  >  OBJECT=LongitudeOfMaximumLatitude;
>  >  Value=-9999.9;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=LongitudeOfMaximumLatitude;
>  >  OBJECT=SpatialCoverageType;
>  >  Value="Horizontal";
>  >  Mandatory=FALSE;
>  >  END_OBJECT=SpatialCoverageType;
>  >  OBJECT=EllipsoidName;
>  >  Value="NULL";
>  >  Mandatory=FALSE;
>  >  END_OBJECT=EllipsoidName;
>  >  OBJECT=EquatorialRadius;
>  >  Value=-9999.9;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=EquatorialRadius;
>  >  OBJECT=DenominatorFlatteningRatio;
>  >  Value=-9999.9;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=DenominatorFlatteningRatio;
>  >  OBJECT=OrbitalModelName;
>  >  Value="NULL";
>  >  Mandatory=FALSE;
>  >  END_OBJECT=OrbitalModelName;
>  >  OBJECT=SemiMajorAxis;
>  >  Value=-9999.9;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=SemiMajorAxis;
>  >  OBJECT=MeanAnomaly;
>  >  Value=-9999.9;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=MeanAnomaly;
>  >  OBJECT=RightAscensionNode;
>  >  Value=-9999.9;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=RightAscensionNode;
>  >  OBJECT=ArgumentOfPerigee;
>  >  Value=-9999.9;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=ArgumentOfPerigee;
>  >  OBJECT=Eccentricity;
>  >  Value=-9999.9;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=Eccentricity;
>  >  OBJECT=Inclination;
>  >  Value=-9999.9;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=Inclination;
>  >  OBJECT=EpochTime;
>  >  Value=99:99:99;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=EpochTime;
>  >  OBJECT=EpochDate;
>  >  Value=9999/99/99;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=EpochDate;
>  >  OBJECT=EpochMillisec;
>  >  Value=-9999.9;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=EpochMillisec;
>  >  OBJECT=WestBoundingCoordinate;
>  >  Value=-180;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=WestBoundingCoordinate;
>  >  OBJECT=EastBoundingCoordinate;
>  >  Value=180;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=EastBoundingCoordinate;
>  >  OBJECT=NorthBoundingCoordinate;
>  >  Value=50;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=NorthBoundingCoordinate;
>  >  OBJECT=SouthBoundingCoordinate;
>  >  Value=-50;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=SouthBoundingCoordinate;
>  >  OBJECT=CenterLatitude;
>  >  Value=-9999.9;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=CenterLatitude;
>  >  OBJECT=CenterLongitude;
>  >  Value=-9999.9;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=CenterLongitude;
>  >  OBJECT=RadiusValue;
>  >  Value=-9999.9;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=RadiusValue;
>  >  OBJECT=LatitudeResolution;
>  >  Value=".25deg";
>  >  Mandatory=FALSE;
>  >  END_OBJECT=LatitudeResolution;
>  >  OBJECT=LongitudeResolution;
>  >  Value=".25deg";
>  >  Mandatory=FALSE;
>  >  END_OBJECT=LongitudeResolution;
>  >  OBJECT=GeographicCoordinateUnits;
>  >  Value="Decimal Degrees";
>  >  Mandatory=FALSE;
>  >  END_OBJECT=GeographicCoordinateUnits;
>  >  OBJECT=TemporalRangeType;
>  >  Value="Continuous Range";
>  >  Mandatory=FALSE;
>  >  END_OBJECT=TemporalRangeType;
>  >  OBJECT=QualityAssuranceParameterName;
>  >  Value="ScienceQualityFlag";
>  >  Mandatory=FALSE;
>  >  END_OBJECT=QualityAssuranceParameterName;
>  >  OBJECT=QualityAssuranceParameterValue;
>  >  Value="NOT BEING INVESTIGATED";
>  >  Mandatory=FALSE;
>  >  END_OBJECT=QualityAssuranceParameterValue;
>  >  OBJECT=ReprocessingActual;
>  >  Value="NULL";
>  >  Mandatory=FALSE;
>  >  END_OBJECT=ReprocessingActual;
>  >  OBJECT=BrowsePointer;
>  >  Value="3B43_BR.100401.6A.PNG";
>  >  Mandatory=FALSE;
>  >  END_OBJECT=BrowsePointer;
>  >  OBJECT=ScienceContact;
>  >  Value="George Huffman";
>  >  Mandatory=FALSE;
>  >  END_OBJECT=ScienceContact;
>  >  OBJECT=MeanMotion;
>  >  Value=-9999.9;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=MeanMotion;
>  >  OBJECT=OrbitAdjustFlag;
>  >  Value=-9999;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=OrbitAdjustFlag;
>  >  OBJECT=AttitudeModeFlag;
>  >  Value=-9999;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=AttitudeModeFlag;
>  >  OBJECT=SolarBetaAngleAtBeginningOfGranule;
>  >  Value=-9999.9;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=SolarBetaAngleAtBeginningOfGranule;
>  >  OBJECT=SolarBetaAngleAtEndOfGranule;
>  >  Value=-9999.9;
>  >  Mandatory=FALSE;
>  >  END_OBJECT=SolarBetaAngleAtEndOfGranule;
>  >  OBJECT=SensorAlignment;
>  >  Value="NULL";
>  >  Mandatory=FALSE;
>  >  END_OBJECT=SensorAlignment;
>  >  OBJECT=SensorAlignmentChannelOffsets;
>  >  Value="NULL";
>  >  Mandatory=FALSE;
>  >  END_OBJECT=SensorAlignmentChannelOffsets;
>  >  OBJECT=ScanPathModel;
>  >  Value="NULL";
>  >  Mandatory=FALSE;
>  >  END_OBJECT=ScanPathModel;
>  >  OBJECT=ScanPathModelParam;
>  >  Value="NULL";
>  >  Mandatory=FALSE;
>  >  END_OBJECT=ScanPathModelParam;
>  >  OBJECT=EphemerisFileID;
>  >  Value="NULL";
>  >  Mandatory=FALSE;
>  >  END_OBJECT=EphemerisFileID;
>  >  > Hi,
>  >  > I ran gdalinfo on some HDF4 files and no subdataset shows up.
>  >  > The data is available for download at this website: http://mirador.gsfc.nasa.gov/cgi-bin/mirador/presentNavigation.pl?tree=project&project=TRMM&dataGroup=Gridded&dataset=3B43:%20Monthly%200.25%20x%200.25%20degree%20merged%20TRMM%20and%20other%20sources%20estimates&version=006
>  >  > I tried reading those some file on:
>  >  > - Idrisi
>  >  > - ArcGIS 9.3
>  >  > - ArcGIS 10 (RC)
>  >  > - Erdas
>  >  > They do identify the internal datasets but they cannot identify the reference system and the images they are flipped by 90' clockwise. But that is not due to rotation. I would guess. It is more like a misinterpretation of the dimension parameter, taking rows as columns and columns as rows.  It looks like the documentation for that particular product is missing here: http://mirador.gsfc.nasa.gov/cgi-bin/mirador/servcoll.pl?helpmenuclass=inventory&SearchButton=Search%20GES-DISC
>  >  > Does anybody has a clue?
>  >  > BTW. There is a netCDF version of that data that also has some issues.
>  >  > Regards,
>  >  > Ivan
>  >  > _______________________________________________
>  >  > gdal-dev mailing list
>  >  > gdal-dev at lists.osgeo.org
>  >  > http://lists.osgeo.org/mailman/listinfo/gdal-dev
