[gdal-dev] Unhandled Exception.
benang at cs.its.ac.id
Tue May 25 23:02:40 EDT 2010
Thanks alot. I'll try that.
Mateusz Loskot wrote:
> On 25/05/10 10:53, benang at cs.its.ac.id wrote:
>> Hi, I tried to run the example in the tutorial. But I've got an
>> unhandled
>> exception at the GDALAllRegister(). This is the call stack:
>> Oh yeah BTW I build GDAL from its source, not the pre-compiled one. And
>> I
>> use the vcproject that uses nmake.
>> So, why is this happening? What should I do to solve this? Thanks in
>> advance.
> Either rebuild GDAL with /MDd or rebuild your program with /MD.
> Should help.
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
Fare thee well,
Bawenang R. P. P.
"Kuaci is good. And coffee makes it better..."
http://www.its.ac.id
