[gdal-dev] Re: Gdal.Allregister Error
Tamas Szekeres
szekerest at gmail.com
Wed May 26 17:31:51 EDT 2010
While I'm not sure what kind of binaries you are testing with, I would
somewhat suggest to use a package from http://vbkto.dyndns.org/sdk/ which
should contain all the required dll-s.
gdal_wrap.dll is the unmanaged part of the bindings and it should also be
available to load by the application at run time. As a last resort you could
also use a file monitoring tool like
ProcMon<http://technet.microsoft.com/en-us/sysinternals/bb896645.aspx>to
identify the dll-s which could not be loaded.
Best regards,
Tamas
2010/5/26 radioheadCDA <chrisaustin2009 at gmail.com>
> I got it to recognize the file but its saying that it can't find an entry
> point in the dll....this is really aggravating ha
> http://osgeo-org.1803224.n2.nabble.com/Gdal-Allregister-Error-tp5104079p5105091.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100526/d60c3e74/attachment.html
