[gdal-dev] ESRI text format?
Pinner, Luke
Luke.Pinner at environment.gov.au
Sun May 30 20:10:50 EDT 2010
It's the output from the ArcGIS "Write Features to Text File (Samples)"
tool. The "format" is documented here:
http://help.arcgis.com/EN/ArcGISDesktop/10.0/help/index.html#//00pv00000
00z000000.htm
Even ESRI use Python to read/write it :)
Apparently it's deprecated though...
Luke
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Christopher
Barker
Sent: Saturday, 29 May 2010 3:45 AM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] ESRI text format?
Ralf Suhr wrote:
> the text is a edit-session from ArcGIS. ogr2ogr can't read this.
In this case, I need to write it, but thanks -- I'm sure the same
applies.
Mateusz Loskot wrote:
> Surely it can...with help of simple script in Perl or Python it
> could be a few minutes of work.
Sure, and that's what I've done, but then OGR is not writing it, I am
writing it with Python -- which I agree is not that big a deal but still
harder than one command line with ogr2ogr.
It doesn't really sound like this is a "format" that it would make sense
to support -- which is probably why OGR doesn't support it.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
Chris.Barker at noaa.gov
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
If you have received this transmission in error please notify us immediately by return e-mail and delete all copies. If this e-mail or any attachments have been sent to you in error, that error does not constitute waiver of any confidentiality, privilege or copyright in respect of information in the e-mail or attachments.
Please consider the environment before printing this email.
