[gdal-dev] gdal_merge / negative size
Chaitanya kumar CH
chaitanya.ch at gmail.com
Tue Nov 2 03:51:39 EDT 2010
Ghislain,
It may be counter intuitive to have smaller y-coordinate for lower
On Tue, Nov 2, 2010 at 12:34 AM, Ghislain Picard <
ghislain.picard at lgge.obs.ujf-grenoble.fr> wrote:
> Hi All,
> I have an image having y-coordinate increasing in the downward direction.
> To display the image, the pixel size is -1000 on the y-axis (see ENVI
> header file below). This works perfectly except in gdal_merge when use to
> clip the raster (using QGis GdalTools(s plugin for instance).
> For instance:
> gdal_merge.py -ul_lr
> 95926.7879548 490702.415307 2036599.49812 -1014610.25721
> fails because the output image size calculated by gdal_merge is negative.
> Inverting the y-coordinates like this:
> 95926.7879548 -1014610.25721 2036599.49812 490702.415307
> works but it is counter-intuitive as the lower-right point should have a
> smaller y-coordinate than the upper-left point.
> It seems the size calculated by gdal_merge does not account for the sign of
> the pixel size.
> Ghislain
> ENVI
> description = {
> File Imported into ENVI.}
> samples = 5601
> lines = 5601
> bands = 1
> header offset = 0
> file type = ENVI Standard
> data type = 4
> interleave = bsq
> sensor type = Unknown
> byte order = 0
> no data = 0
> wavelength units = Unknown
> map info = {Polar Stereographic, 1, 1, -2800500, -2800500, 1000,
> -1000,WGS-84}
> projection info = {31, 6378137, 6356752.314245179, -71, 0, 0, 0,WGS-84,
> Polar Stereographic}
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101102/1d47df04/attachment.html
