[gdal-dev] _gdal_array not found
Jorge Arévalo jorge.arevalo at deimos-space.com
Tue Nov 2 14:37:05 EDT 2010
On Fri, Oct 29, 2010 at 6:18 PM, Christopher Barker
<Chris.Barker at noaa.gov> wrote:
> On 10/29/10 3:36 AM, Jorge Arévalo wrote:
>> I find several files missing in the newer one (2.7). Files like
>> "_gdal_array.py", "_gdal_array.pyc", "_gdalconst.py",
>> "_gdal_array.so", "_gdalconst.so", "_gdal.py", "_gdal.pyc",
>> "_gdal.so", and so on. All the missing files starting with "_"
>> The newer installation (2.7) was created from sources, building python
>> 2.7 and GDAL 1.7.2 (with "configure --with-python&&  make&&  make
>> install"). The previous installation (2.4) was created from package
>> manager (Suse YaST).
> Something went wrong with your build -- check the messages carefully. And
> yes, installing numpy from source should give you what you need.
> Do make sure that you are using the same version of python for everything.
> HTH,
> -Chris
> Christopher Barker, Ph.D.
> Oceanographer
> Emergency Response Division
> NOAA/NOS/OR&R            (206) 526-6959   voice
> 7600 Sand Point Way NE   (206) 526-6329   fax
> Seattle, WA  98115       (206) 526-6317   main reception
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I finally compiled all the stuff properly, but I can't remember what
was my mistake :-(. Thanks for your help, anyway
Best regards,
Jorge Arévalo
Internet & Mobilty Division, DEIMOS
http://mobility.grupodeimos.com/
http://gis4free.wordpress.com
