[gdal-dev] Re: corner coords in tif vs ecw
kmayall kmayall at gmail.com
Thu Nov 4 15:14:38 EDT 2010
Without the XML file, it uses values from the coordinate system.
Driver: ECW/ERMapper Compressed Wavelets
Files: myecw.ecw
Size is 2353, 2353
Coordinate System is `'
Origin = (535999.787499999980000,129999.862499999990000)
Pixel Size = (0.425000000000000,-0.425000000000000)
Corner Coordinates:
Upper Left  (  535999.787,  129999.862)
Lower Left  (  535999.787,  128999.837)
Upper Right (  536999.813,  129999.862)
Lower Right (  536999.813,  128999.837)
Center      (  536499.800,  129499.850)
Band 1 Block=2353x1 Type=Byte, ColorInterp=Red
  Overviews: arbitrary
Band 2 Block=2353x1 Type=Byte, ColorInterp=Green
Band 3 Block=2353x1 Type=Byte, ColorInterp=Blue
On Thu, Nov 4, 2010 at 3:56 PM, Jean-Claude Repetto [via OSGeo.org] <
ml-node+5706506-526523884-294829 at n2.nabble.com<ml-node%2B5706506-526523884-294829 at n2.nabble.com>
> wrote:
> On 11/04/10 19:25, kmayall wrote:
> > Sorry, I've been on hiatus for a while.
> > ECW Image Header Editor shows the top left coords using values from the
> > coordinate system (screenshot attached), while the gdalinfo results show
> > the corner coords in pixels.
> > So there's likely nothing wrong with my ecw file, just a quirk in the
> > gdalinfo display?
> Yes, I think so !
> What does gdalinfo display after deleting (or renaming) the file
> f:\gisdata\test\myecw.ecw.aux.xml ?
> Jean-Claude
> gdal-dev mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5706506&i=0>
>  View message @
> http://osgeo-org.1803224.n2.nabble.com/gdal-dev-corner-coords-in-tif-vs-ecw-tp5608144p5706506.html
> To unsubscribe from [gdal-dev] corner coords in tif vs ecw, click here<http://osgeo-org.1803224.n2.nabble.com/template/TplServlet.jtp?tpl=unsubscribe_by_code&node=5608144&code=a21heWFsbEBnbWFpbC5jb218NTYwODE0NHwtMTM2OTUxMTQ4NA==>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-dev-corner-coords-in-tif-vs-ecw-tp5608144p5706573.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101104/64e2aa87/attachment-0001.html
