[gdal-dev] Motion: Promote GDAL/OGR 1.7.3RC2 to final release
Peter Hopfgartner
peter.hopfgartner at r3-gis.com
Tue Nov 9 10:04:18 EST 2010
I wrapped a quick rpm package, installed the rpms and tried to run autotest. The tests comes to this point:
Running tests from gcore/mask.py
TEST: mask_1 ... success
TEST: mask_2 ... success
TEST: mask_3 ... success
TEST: mask_4 ... success
TEST: mask_5 ... ERROR 1: ZIPDecode:tmp/mask_4.pnm.msk: Decoding error at scanline 0, incorrect header check
ERROR 1: TIFFReadEncodedTile() failed.
ERROR 1: IReadBlock failed at X offset 0, Y offset 0
ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
Segmentation fault
The platform id CentOS 5.5/x86_64, with some packages from EPEL and elgis.
Regards,
Peter Hopfgartner
R3 GIS Srl - GmbH
http://www.r3-gis.com
--------Frank Warmerdam <warmerdam at pobox.com> wrote--------
Subject: [gdal-dev] Motion: Promote GDAL/OGR 1.7.3RC2 to final release
Date: 08.11.2010 21:22
>PSC members,
>I've run the autotests in a few environments and things seems solid
>to me. Please vote when you have had a chance to examine the release
>candidate. Anyone else who finds problems should also speak up of
>course.
>+1 Frank
>I set the clouds in motion - turn up | Frank Warmerdam,
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | Geospatial Programmer for Rent
>_______________________________________________
>gdal-dev mailing list
>gdal-dev at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/gdal-dev
