[gdal-dev] An error in building overviews for
Frank Warmerdam
warmerdam at pobox.com
Fri Nov 12 11:02:55 EST 2010
Zhenyu Lu wrote:
> Hi, Even:
> I have used the tool you mentioned. There is a gdaladdo utility in
> GDAL1.5.2. But still it didn't work with the .img file in my computer.
> Then I realized that since I've used these .img files in ArcGIS and
> Erdas before. These software must automatically create the .rrd files.
> That explains why I can't use the following code
> "dataset.BuildOverviews("NEAREST", pOverviewList);".
> It turns out to be that the reason why the ".tif" file works using the
> previous code is because there is a .aux file together with the .rrd
> file. It seems that the .aux file can be both read and written.
> Thanks a lot for all the help and information.
Indeed this is likely to be a situation where the behavior is confusing. It
may well be better handled with the most recent code. If you find things
still do not seem to work in a reasonable way with the current (trunk) code
please feel free to file a bug report.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
