[gdal-dev] Re: remove coordinate system info from a GTiff
Eloi Ribeiro
eloi.ribeiro at gmail.com
Mon Nov 15 08:32:54 EST 2010
Thanks Jukka!
It worked fine!
By,
Eloi Ribeiro
GIS Analyst
39,45º -4,40º
http://eloiribeiro.wordpress.com
On Mon, Nov 15, 2010 at 14:07, Jukka Rahkonen <jukka.rahkonen at mmmtike.fi>wrote:
> Eloi Ribeiro <eloi.ribeiro <at> gmail.com> writes:
> > Hi all,
> > By mistake I have assigned the wrong coordinate system to a GTiff image
> and
> deleted the original file.
> > How can I remove coordinate system info from a GTiff and then assign the
> correct one with no warping involved in the process?
> > Thanks for your help!
> Hi,
> Make first a clean intermediate tiff file with gdal_translate by using -co
> PROFILE=BASELINE and -co TFW=YES, then convert this plain tiff by using
> -a_srs.
> There can be more sophisticated solutions.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101115/2cd2b764/attachment-0001.html
