[gdal-dev] OCI: ogrinfo from normal table
Sebastian E. Ovide sebastian.ovide at gmail.com
Mon Nov 15 10:46:54 EST 2010
Hi All,
I have a table which has an X and Y columns. It doesn't have a geometry
column.
In order to read geometries created on the fly, I'm trying to use ogrinfo
with the -sql parameter.
So the Oracle query is:
 Select T.Entry_Id id, SDO_GEOMETRY(2001,8307,SDO_POINT_TYPE(T.Xcoord,
T.Ycoord, NULL), NULL, NULL) geom From Lookupindex T;
and therefore the ogrinfo command is:
 ogrinfo OCI:la002/la002 at 192.168.60.70/MFUATDB -sql 'Select T.Entry_Id id,
SDO_GEOMETRY(2001,8307,SDO_POINT_TYPE(T.Xcoord, T.Ycoord, NULL), NULL, NULL)
geom From Lookupindex T;'
I would expect a list of points... but I'm getting this:
INFO: Open of `OCI:la002/la002 at 192.168.60.70/MFUATDB'
      using driver `OCI' successful.
ERROR 1: ORA-00911: invalid character
 in Select T.Entry_Id id, SDO_GEOMETRY(2001,8307,SDO_POINT_TYPE(T.Xcoord,
any ideas ?
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101115/a79b22c8/attachment.html
