[gdal-dev] How do I find the anchor point in file?
Frank Warmerdam
warmerdam at pobox.com
Wed Nov 17 12:32:00 EST 2010
Todd Smith wrote:
> Yeah and a little more investigation on my part showed me that Arc/Info
> ASCII Grid files have their origin in the upper left anyway, even though
> they have their lat/long coords in the lower left. This is from
> gCore\rasterio.cpp (line 243in 1.6.2). In my RGB reads, with a
> nPixelSpace of 3 and a nBufDataSize of 1, I could get away get away with
> having GDAL "flip" my file data for me by using a negative value for
> nLineSpace because GDALCopyWords handled that. Memcpy doesn't do well
> with a negative value for nLineSpace :). It looks like I'll have to
> have another function flip my buffer from top to bottom after my
> RasterIO call.
Todd,
Negative values are supposed to be accepted for line spacings. If you have
found a case where it fails please file a ticket on the issue.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
