[gdal-dev] GeoPDF and neatline. Not correct when neatline is
smaller than PDF page.
Robert Zermeno
refriguy68 at yahoo.com
Thu Nov 18 09:28:18 EST 2010
Even and GDAL community, Sorry if everyone has already received this message. I was I hope you can enlighten me on the issue of computing neatline values. The solution presented in GDAL (I am using the trunk version download from 11-16-2010) to compute the neatline values is not fully correct (file: pdfdataset.cpp lines 743-749) specifically: double X = poDS->adfGeoTransform[0] + x * poDS->adfGeoTransform[1] +
y * poDS->adfGeoTransform[2];
double Y = poDS->adfGeoTransform[3] + x * poDS->adfGeoTransform[4] +
y * poDS->adfGeoTransform[5]; but to understand the two lines of code above, you need to understand what was done before. The case where it is correct is when: 1. - PDF is OGC Standard - Neatline values are the corner points of the image. The case when GDAL does not compute correct Neatline values is when: 2. -PDF is OGC Standard - Neatline values are not the corner points of the image. Let me elaborate on the case when it does not compute neatline values correctly. An example file is taken from:http://giigt.tec.army.mil/GeoPDFgallery/AU_NZ_Re-seller/Env_Sample_geo.pdf here is GDAL's output:NOTE: I have modified GDAL code to make default DPI to be 110.
C:\apps>gdalinfo.exe c:\Env_Sample_geo.pdfPDF: OGC Encoding Best Practice style detected
PDF: LGIDict Version : 2.1
PDF: This is a the largest neatline for now
PDF: CTM[0] = 1.4111110661
PDF: CTM[1] = 0
PDF: CTM[2] = 0
PDF: CTM[3] = 1.4111110661
PDF: CTM[4] = 725048.2016161948
PDF: CTM[5] = 7671532.018003316
PDF: Datum = HEN
PDF: Projection.ProjectionType = TC
GDAL: GDALOpen(c:\Env_Sample_geo.pdf, this=026BE308) succeeds as PDF.
Driver: PDF/Geospatial PDF
GDAL: GDALDefaultOverviews::OverviewScan()
Files: c:\Env_Sample_geo.pdf
Size is 1285, 909
Coordinate System is:
PROJCS["UTM Zone 55, Southern Hemisphere",
GEOGCS["unknown",
DATUM["unknown",
SPHEROID["International 1924",6378388,297],
TOWGS84[-333,-222,114,0,0,0,0]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",147],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",10000000],
UNIT["Meter",1]]
Origin = (725048.201616194800000,7672372.337465400800000)
Pixel Size = (0.923636334174545,-0.923636334174545)
GeoTransform =
725048.20161619480, 0.92363633417454549, 0.00000000000000000
7672372.3374654008, -0.0000000000000000, -0.92363633417454549Metadata:
NEATLINE=POLYGON ((725124.91858881968 7671671.0094531905,725124.91858881968 76
72311.3218032392,726165.27821117197 7672311.3218032392,726165.27821117197 767167
1.0094531905,725124.91858881968 7671671.0094531905))
OGRCT: Source: +proj=utm +zone=55 +south +ellps=intl +towgs84=-333,-222,114,0,0,
0,0 +units=m +no_defs
OGRCT: Target: +proj=longlat +ellps=intl +towgs84=-333,-222,114,0,0,0,0 +no_defs
Corner Coordinates:
Upper Left ( 725048.202, 7672372.337) (149d 9'55.60"E, 21d 2' 7.62"S)
Lower Left ( 725048.202, 7671532.752) (149d 9'55.99"E, 21d 2'34.91"S)
Upper Right ( 726235.074, 7672372.337) (149d10'36.69"E, 21d 2' 7.10"S)
Lower Right ( 726235.074, 7671532.752) (149d10'37.09"E, 21d 2'34.39"S)
Center ( 725641.638, 7671952.545) (149d10'16.34"E, 21d 2'21.00"S)
Band 1 Block=1285x1 Type=Byte, ColorInterp=Red
Band 2 Block=1285x1 Type=Byte, ColorInterp=Green
Band 3 Block=1285x1 Type=Byte, ColorInterp=Blue
GDAL: GDALClose(c:\Env_Sample_geo.pdf, this=026BE308)
GDAL: GDALDeregister_GTiff() called. The Corner points reported should be accurate. I have an unclassified file which the neatline
is the height and width of the image, so the corner points are the neatlines. In that case, all
points are correct.The issues is when you have a defined neatline within the PDF that is smaller than the image we
are looking at (i.e. Neatline != MediaBox)FOr this file, the top-left corner of the neatline is very accurate, but the top-right, bottom-right
are way off.
Can you describe to me how you computed the Neatline values (X,Y). I understand that the CTM is
the PDF page coordinate space transformation to projected coordinate system (This file is UTM (Northing/Easting).Then you will use that information to compute the Transformation matrix of projection coordinates
onto the image space.
Once you have found the GeoTransform you use that information with the NeatLine values registered
in the PDF to translate the PDF page coordinate to projected coordinates (this case, Northing/Easting).
The problem I found, is the neatline values are all not accurate. The values presented do not provided an
acceptable bounding region that defines the coordinate space.Can you please provide input to help me figure out why this is not working accurately? Specifically, it would
be nice if you can explain how, and why, you obtained the computations of the GeoTransform
(Look at file pdfdataset.cpp lines 682-689) and Neatline values (Look at file pdfdataset.cpp lines 712-718)
It would be nice if you can take the time to help me resolve this.
Summary:1. From above, please explain your logic to compute the neatline, geotransform
2. when computing:
double y = poDS->nRasterYSize - poRing->getY(i) * dfPixelPerPt;
Line 713 in pdfdataset.cpp why are you doing that?
I have tried to explain in a simple manner. However, I know I did not do the best job because
I am still trying to wrap my brain around how transforming from PDF page --> projected coords (UTM)
by using the CTM to create the GeoTransform (projected Coords affine transformation) and then use it
to compute the proper UTM coordinate for a given neatline point provided in the PDF.
Robert
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101118/fea58c15/attachment-0001.html
