[gdal-dev] gdalinfo, map unit DD and epsg:9108
yrrman yrrman
yrrman at gmail.com
Fri Nov 19 05:36:31 EST 2010
Hi everyone,
I'm new to this list and would therefore like to say "hello and thanks
for gdal" in the first place :-)
I just came across a minor problem where I would like to ask for your advice -
the Global Landcover set GLC2000 is available in grid format from [0].
Associated with it is the .hdr file with the projection description
[2].
Apparently the map units are in decimal degree.
When I ask gdalinfo, I get the WKT description of the SRS, see [3]
Everything's fine with this, I only came across the UNIT-Field
UNIT["degree",0.0174532925199433, AUTHORITY["EPSG","9108"]],
where the unit is degree, defined according to epsg:9108. When you
look up epsg:9108 in the epsg registry [1] you get as Unit of Measure:
Code: EPSG::9108 - Name: degree minute second hemisphere (i.e. not
decimal degree)
Shouldn't this rather be epsg:9102 then?
Code: EPSG::9102 Name: degree, 1 degree: 0.017453292519943278 radian
As I said, it's not very important, just out of curiousity.
I'm using
GDAL 1.7.0b2, FWTools 2.4.7, released 2010/01/19
Thanks a lot and kind regards,
Chris
PS
I had registered and sent this mail already days ago after some
problems with registering
("googlemail" vs. "gmail"), however the mail was then neither rejected
nor appeared on the list.
I switched to gmail and re-registered now and hope it will work now.
Or is this list moderated and the mail has been
silently rejected? :-) Thanks again to Frank who helped with the
registration problem - and greetings, Chris.
[0] http://bioval.jrc.ec.europa.eu/products/glc2000/products.php
[1] http://www.epsg-registry.org/
[2] glc2000_v1_1_projinfo.hdr:
BANDS: 1
ROWS: 16353
COLS: 40320
INTERLEAVING: NA
DATATYPE: U8
BYTE_ORDER: NA
UL_X_COORDINATE: -180.000000
UL_Y_COORDINATE: 89.991071
LR_X_COORDINATE: 179.991070
LR_Y_COORDINATE: -56.008928
PIXEL_WIDTH: 0.0089285714
PIXEL_HEIGHT: 0.0089285714
MAP_UNITS: DD
PROJECTION_NAME: Geographic (Lat/Lon)
PROJECTION_ZONE: 0
PROJECTION_PARAMETERS:
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
SPHEROID_NAME: WGS 84
SEMI_MAJOR_AXIS: 6378137.000000
SEMI_MINOR_AXIS: 6356752.314245
E_SQUARED: 0.006694
RADIUS: 6371007.180918
[3] gdalinfo output:
Driver: AIG/Arc/Info Binary Grid
Files: glc2000_v1_1
glc2000_v1_1\dblbnd.adf
glc2000_v1_1\hdr.adf
glc2000_v1_1\log
glc2000_v1_1\metadata.xml
glc2000_v1_1\prj.adf
glc2000_v1_1\sta.adf
glc2000_v1_1\vat.adf
glc2000_v1_1\w001001.adf
glc2000_v1_1\w001001x.adf
Size is 40320, 16353
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
AUTHORITY["EPSG","4326"]]
Origin = (-180.004464285700010,89.995535666300043)
Pixel Size = (0.008928571400000,-0.008928571400000)
Corner Coordinates:
Upper Left (-180.0044643, 89.9955357) (180d 0'16.07"W, 89d59'43.93"N)
Lower Left (-180.0044643, -56.0133924) (180d 0'16.07"W, 56d 0'48.21"S)
Upper Right ( 179.9955346, 89.9955357) (179d59'43.92"E, 89d59'43.93"N)
Lower Right ( 179.9955346, -56.0133924) (179d59'43.92"E, 56d 0'48.21"S)
Center ( -0.0044649, 16.9910716) ( 0d 0'16.07"W, 16d59'27.86"N)
Band 1 Block=256x4 Type=Byte, ColorInterp=Palette
Min=1.000 Max=23.000
NoData Value=255
Metadata:
LAYER_TYPE=thematic
Color Table (RGB with 256 entries)
0: 0,0,0,255 [..]
