[gdal-dev] Re: [GRASS-dev] ERROR: G_realloc: during r.to.vect call
antonio.rocha at deimos.com.pt
Sun Nov 21 05:21:45 EST 2010
I'm sorry I sent this message to the wrong mailing list
Here goes the reply to your message markus
Hello Markus
I believe it's ok:
projection: 1 (UTM)
zone: -24
datum: wgs84
ellipsoid: wgs84
north: 9305500.00000001
south: 9095770.00000001
west: 444000
east: 689130
nsres: 30
ewres: 30
rows: 6991
cols: 8171
cells: 57123461
And my raster is:
| Type of Map: raster Number of Categories:
3 |
| Data Type:
CELL |
| Rows:
6991 |
| Columns:
8171 |
| Total Cells:
57123461 |
| Projection: UTM (zone
-24) |
| N: 9305500.00000001 S: 9095770.00000001 Res:
30 |
| E: 689130 W: 444000 Res:
30 |
| Range of data: min = 0 max =
3 |
So it matches. What might be causing this error?
Antonio
