[gdal-dev] problem with gdalwarp in 1.7 - SOLVED
geographika
geographika at gmail.com
Sun Nov 21 10:25:20 EST 2010
Thanks to both Frank and Chaitanya this is now resolved.
Adding in the coordinate system to my GeoJSON solved the issue in the
latest versions of GDAL.
Leaving this out did not produce errors using ogrinfo, but it did not
display the feature as WKT until the CRS was added in.
"type": "Polygon",
* "crs": {
"type": "EPSG",
"properties": {
"code": 29902
"coordinates": [
123608.61199436858,
206164.3985653462
On 21/11/2010 15:38, Chaitanya kumar CH wrote:
> Seth,
> You can obtain the WKT of the geometries in a vector data source by
> using ogrinfo with the -al option.
> (http://www.gdal.org/ogrinfo.html)
> On Sun, Nov 21, 2010 at 6:20 PM, geographika <geographika at gmail.com
> <mailto:geographika at gmail.com>> wrote:
> On 19/11/2010 18:04, Frank Warmerdam wrote:
> geographika wrote:
> Hi,
> I have upgraded from GDAL 1.6 (32bit Windows) to 1.7 (64
> bit Windows) and the following command no longer works:
> C:\mapserver\bin\gdal\apps\gdalwarp
> C:\Data\Rasters\MiscSuit.tif C:\RasterClips\mytest.tif
> -cutline c:\RasterClips\hello.json -te 118008.672141
> 177232.164284 138695.761666 206164.398565 -dstnodata -9999
> I get the following message in the command prompt:
> Creating output file that is 414P x 579L.
> Processing input file C:\Data\Rasters\MiscSuit.tif.
> for band 1, destination nodata value has been clamped
> to 0, the original value being out of range.
> ERROR 1: Failed to parse CUTLINE geometry wkt.
> The CUTLINE is valid GeoJSON (but would clearly be invalid
> WKT) and produces the correct results in 1.6.
> The ogr formats lists GeoJSON as read/write.
> I am using 64-bit builds of GDAL taken from
> http://vbkto.dyndns.org/sdk/
> I have also tried using the development version of GDAL
> 1.8dev but get the same message. If I do not use a CUTLINE
> the gdalwarp completes successfully but the new image does
> not contain any data from my original image (all cells are
> NoData).
> Seth,
> Can you make the .json file available? Does it work with OGR?
> Try
> ogrinfo on it.
> Hmm, tracking through the code the LoadCutline() function in
> gdalwarp.cpp
> will read from the OGR datasource and convert the geometry to
> WKT which is
> attached to the cutline property of the warp. Later
> GDALWarpOperation::
> Initialize() turns that into a polygon object and that is
> where the message
> is coming from. So I am *suspecting* improper WKT of some
> type is getting
> produced somehow. We will really need to see the WKT that is
> causing the
> error to know more.
> If you are comfortable rebuilding things then try changing:
> const char *pszCutlineWKT =
> CSLFetchNameValue( psOptions->papszWarpOptions,
> "CUTLINE" );
> if( pszCutlineWKT )
> in the file gdal/alg/gdalwarpoperation.cpp to something like:
> "CUTLINE" );
> if( pszCutlineWKT )
> printf( "WKT = %s\n", pszCutlineWKT );
> Best regards,
> Thanks very much for your reply Frank.
> I have uploaded the GeoJSON to
> http://geographika.co.uk/downloads/test.json
> Running ogrinfo C:\test.json on the file produces the following
> results:
> ERROR 4: GeoJSON Driver doesn't support update.
> Had to open data source read-only.
> INFO: Open of `C:\RasterClips\hello.json'
> using driver `GeoJSON' successful.
> 1: OGRGeoJSON (Polygon)
> Is it possible to use the ogr2ogr to convert GeoJSON to WKT to
> check if this is successful? WKT is not in the list of formats at
> http://www.gdal.org/ogr/ogr_formats.html
> Compiling a 64bit version of GDAL is on my list of things to
> learn, so I will try your second suggestion then.
> The gdalwarp with the same GeoJSON works in 1.6 but it does throw
> up the warning that:
> "the source raster dataset and the input vector layer do not have
> the same SRS. Results will be probably incorrect."
> Regards,
> Seth
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101121/56a697db/attachment.html
