[gdal-dev] Xerces 3.0.1 and Gdal 1.7
Srikanth srikanth1947 at gmail.com
Fri Nov 26 08:37:22 EST 2010
Hi Everyone,
Its been a long time ,i have interacted. off late i have tried building gdal
with the xerces support to read/write gml.
I have done using several options as mentioned in
http://trac.osgeo.org/gdal/ticket/1988 but none has helped. Everytime parser
headers have been found but it has failed to detect libraries.
My folder structure for xerces is /local
                                                    bin
                                                    include ( xercesc folder
with standard structure)
                                                    lib. and within lib i
have libxerces-c.a , libxerces-c.dll.a , libxerces-c.la.
I am using msys with mingw 3.2 and gcc 4.4 for compilation.
Do I need to change the configure file of gdal or follow different process ?
And I have read document drv_gml.html in /ogr_formats/gml. It is speaking
about gml's support with xerces but was not clear with expat. Is GML reading
and writing supported through Expat also ?
Any advice would be of great help. Thank you.
Regards,
Srikanth
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101126/4bf62c39/attachment-0001.html
