[gdal-dev] Delete a sqlite database
Even Rouault
even.rouault at mines-paris.org
Sun Nov 28 11:23:12 EST 2010
Le lundi 22 novembre 2010 10:26:26, Ludovic Granjon a écrit :
> Hi all
> I try in a python script to delete a sqlite database that I use in an
> OGR ExecuteSQL.
> Let me give you an example :
> If I do :
> >>> from osgeo import *
> >>> import os
> >>> datasource = ogr.Open("decoupe.shp")
> >>> layer = datasource.GetLayer()
> >>> joinLayer=datasource.ExecuteSQL("SELECT decoupe.FID as ligne_id,
> c.lFid as ligne_id2, c.count as count FROM decoupe LEFT JOIN
> 'project.sqlite'.comptage c ON decoupe.FID=c.lFid")
You probably need a datasource.ReleaseResultSet(joinLayer) at that point
> >>> datasource.Destroy()
> It seems that there still a connection to my sqlite database and I can't
> delete it.
> When I try on MS Windows (There's no error on linux) :
> >>> os.remove('project.sqlite')
> I have :
> Traceback (most recent call last):
> File "<pyshell#5>", line 1, in <module>
> WindowsError: [Error 13] Le processus ne peut pas accéder au fichier car
> ce fichier est utilisé par un autre processus: 'project.sqlite'
> Do you know a way to do that ?
> Thanks
> Best regards
> Ludovic
