[gdal-dev] Error building GDAL with GEOS on Solaris
Namrata
namrata.r.sorte at gmail.com
Mon Nov 29 03:32:55 EST 2010
I modified few options in configuration script to resolve if any
dependencies, it is as below:
./configure --prefix=/usr/local \
--with-threads \
--with-ogr \
--with-geos=yes \
--without-libtool \
--with-libz=internal \
--with-libtiff=internal \
--with-geotiff=internal \
--without-gif \
--without-pg \
--without-grass \
--without-libgrass \
--without-cfitsio \
--without-pcraster \
--without-netcdf \
--without-png \
--with-jpeg=internal \
--without-gif \
--without-ogdi \
--without-fme \
--without-hdf4 \
--without-hdf5 \
--without-jasper \
--without-ecw \
--without-kakadu \
--without-mrsid \
--without-jp2mrsid \
--without-bsb \
--without-grib \
--without-mysql \
--without-ingres \
--without-xerces \
--without-expat \
--without-odbc \
--without-curl \
--without-sqlite3 \
--without-dwgdirect \
--without-panorama \
--without-idb \
--without-sde \
--without-perl \
--without-php \
--without-ruby \
--without-python \
--without-ogpython \
--with-hide-internal-symbols
Below is my config status:
GDAL is now configured for sparc-sun-solaris2.10
Installation directory: /usr/local
C compiler: gcc -g -O2 -fPIC
C++ compiler: g++ -g -O2 -fPIC
LIBTOOL support: no
LIBZ support: internal
GRASS support: no
CFITSIO support: no
PCRaster support: no
NetCDF support: no
LIBPNG support: no
LIBTIFF support: internal (BigTIFF=yes)
LIBGEOTIFF support: internal
LIBJPEG support: internal
8/12 bit JPEG TIFF: yes
LIBGIF support: no
OGDI support: no
HDF4 support: no
HDF5 support: no
Kakadu support: no
JasPer support: no
ECW support: no
MrSID support: no
MSG support: no
GRIB support: no
EPSILON support: no
cURL support (wms/wcs/...):no
PostgreSQL support: no
MySQL support: no
Ingres support: no
Xerces-C support: no
NAS support: no
Expat support: no
ODBC support: no
PGeo support: no
PCIDSK support: internal
OCI support: no
GEORASTER support: no
SDE support: no
DODS support: no
SQLite support: no
SpatiaLite support: no
DWGdirect support no
INFORMIX DataBlade support:no
GEOS support: yes
VFK support: yes
SWIG Bindings: no
Statically link PROJ.4: no
enable OGR building: yes
enable pthread support: yes
hide internal symbols: no
Now when I execute "make" command I get following error:
g++ -DHAVE_MITAB -g -O2 -fPIC -Wall -Iogrsf_frmts -I.
-I/pool1/innovations/gdal-1.7.1/port -I/pool1/innovations/gdal-1.7.1/gcore
-I/pool1/innovations/gdal-1.7.1/alg -I/pool1/innovations/gdal-1.7.1/ogr
-I/pool1/innovations/gdal-1.7.1/ogr/ogrsf_frmts -DHAVE_GEOS=1
-I/usr/local/include -DOGR_ENABLED -I/pool1/innovations/gdal-1.7.1/port -c
-o ogr_expat.o ogr_expat.cpp
make[1]: Leaving directory `/pool1/innovations/gdal-1.7.1/ogr'
make /pool1/innovations/gdal-1.7.1/libgdal.a
/pool1/innovations/gdal-1.7.1/libgdal.so
make[1]: Entering directory `/pool1/innovations/gdal-1.7.1'
rm -f libgdal.a
ar r /pool1/innovations/gdal-1.7.1/libgdal.a
/pool1/innovations/gdal-1.7.1/frmts/o/*.o
/pool1/innovations/gdal-1.7.1/gcore/*.o
/pool1/innovations/gdal-1.7.1/port/*.o /pool1/innovations/gdal-1.7.1/alg/*.o
/pool1/innovations/gdal-1.7.1/ogr/ogrsf_frmts/o/*.o
./ogr/ogrgeometryfactory.o ./ogr/ogrpoint.o ./ogr/ogrcurve.o
./ogr/ogrlinestring.o ./ogr/ogrlinearring.o ./ogr/ogrpolygon.o
./ogr/ogrutils.o ./ogr/ogrgeometry.o ./ogr/ogrgeometrycollection.o
./ogr/ogrmultipolygon.o ./ogr/ogrsurface.o ./ogr/ogrmultipoint.o
./ogr/ogrmultilinestring.o ./ogr/ogr_api.o ./ogr/ogrfeature.o
./ogr/ogrfeaturedefn.o ./ogr/ogrfeaturequery.o ./ogr/ogrfeaturestyle.o
./ogr/ogrfielddefn.o ./ogr/ogrspatialreference.o ./ogr/ogr_srsnode.o
./ogr/ogr_srs_proj4.o ./ogr/ogr_fromepsg.o ./ogr/ogrct.o ./ogr/ogr_opt.o
./ogr/ogr_srs_esri.o ./ogr/ogr_srs_pci.o ./ogr/ogr_srs_usgs.o
./ogr/ogr_srs_dict.o ./ogr/ogr_srs_panorama.o ./ogr/ogr_srs_ozi.o
./ogr/ogr_srs_erm.o ./ogr/swq.o ./ogr/ogr_srs_validate.o ./ogr/ogr_srs_xml.o
./ogr/ograssemblepolygon.o ./ogr/ogr2gmlgeometry.o ./ogr/gml2ogrgeometry.o
./ogr/ogr_expat.o
/bin/sh: ar: not found
make[1]: *** [/pool1/innovations/gdal-1.7.1/libgdal.a] Error 1
make[1]: Leaving directory `/pool1/innovations/gdal-1.7.1'
make: *** [check-lib] Error 2
Please help me to sort this error.
Thanks,
Namrata
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-dev-Error-building-GDAL-with-GEOS-on-Solaris-tp5776262p5783578.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
