[gdal-dev] PG: does OGR2OGR set the SRID correctly ?
Sebastian E. Ovide
sebastian.ovide at gmail.com
Tue Nov 30 09:58:32 EST 2010
Hi Even,
I've missed that part...
just to confirm that with *psql -d [yourdatabase] -f spatial_ref_sys.sql and
deleting those extra lines created automatically, now I can upload shapes
with the right SRID*
**thanks !
On Tue, Nov 30, 2010 at 2:32 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Sebastian,
> I'd suggest checking what I wrote at the end of my previous email : "Make
> sure
> you've filled the spatial_ref_sys table with the appropriate PostGIS .sql
> script. The '3' you get sounds like the spatial_ref_sys table of this
> database
> was empty and that the PG driver added new entries in it."
> The mentionned .sql script is spatial_ref_sys.sql. See
> http://postgis.refractions.net/documentation/manual-1.5/ch02.html#id2630392
> > I've replaced the -lco 27700 with -a_srs EPSG:27700
> > now select ST_SRID(wkb_geometry) from sebas
> > gives 4...
> > any ideas ?
> > On Tue, Nov 30, 2010 at 10:59 AM, Even Rouault <
> > > wrote:
> > > Selon "Sebastian E. Ovide" <sebastian.ovide at gmail.com>:
> > > Sebastian,
> > > The option "-lco 27700" has no effect. The correct syntax would be
> > > something
> > > like "-lco SRID=27700", but there's no such option, so don't loose your
> > > time
> > > trying that ;-)
> > > The SRID is set automatically by comparing the SRS of the source layer
> with
> > > what
> > > exists in the spatial_ref_sys table (or the one you can set with the
> -a_srs
> > > EPSG:27700 as suggested by Jorge). If there's a match, then the SRID
> from
> > > spatial_ref_sys will be used. Otherwise the PG driver will add a new
> entry
> > > in
> > > the spatial_ref_sys table (and the SRID number will not be equal to the
> > > EPSG
> > > code). Make sure you've filled the spatial_ref_sys table
> > > with the appropriate PostGIS .sql script. The '3' you get sounds like
> the
> > > spatial_ref_sys table of this database was empty and that the PG driver
> > > added
> > > new entries in it.
> > > Best regards,
> > > > Hi All,
> > > > I've just uploaded a shape with
> > > > ogr2ogr -f PostgreSQL "PG:dbname='gis' host='10.0.1.40' port='5432'
> > > > user='gis' password='gis'" sebas.shp -lco 27700 -lco PRECISION=NO
> > > -progress
> > > > -lco OVERWRITE=yes -lco dim=2 -nln sebas -overwrite
> > > > but from
> > > > select ST_SRID(wkb_geometry) from sebas;
> > > > I'm getting 3
> > > > (with
> > > > select ST_SRID(ST_SetSRID(wkb_geometry,27700)) from sebas;
> > > > I'm getting the right value )
> > > > any ideas ?
> > > > Sebastian E. Ovide
> > Sebastian E. Ovide
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101130/db8fd740/attachment.html
