[gdal-dev] GDAL contouring problem
Ole Nielsen
ole.nielsen at aifdr.org
Tue Nov 30 23:44:09 EST 2010
Thanks for explaining the reason why the numeric value of 0.00 doesn't work as a fixed level in gdal_contour while the value of 0 does.
I understand now the reason for this.
However I would have thought one could replace the test for 'zeroness' in
(atof(argv[i+1]) != 0 || EQUAL(argv[i+1], "0"))
with a test for whether argv]i+1] is not empty and can be converted to a numeric value.
This would be a duck-typing approach and more robust in my humble opinion.
Best regards
Ole Nielsen
-----Original Message-----
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of gdal-dev-request at lists.osgeo.org
Sent: Monday, 29 November 2010 8:41 PM
To: gdal-dev at lists.osgeo.org
Subject: gdal-dev Digest, Vol 78, Issue 64
Send gdal-dev mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/gdal-dev
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
gdal-dev-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of gdal-dev digest..."
Today's Topics:
1. Re: GDAL contouring problem (Frank Warmerdam)
2. Re: GDAL contouring problem (Francis Markham)
3. Re: Delete a sqlite database (Ludovic Granjon)
4. Re: Error building GDAL with GEOS on Solaris (Namrata)
5. Making non-rectangular image edges transparent
(Just van den Broecke)
6. geotiff conflict (Julien Malik)
7. Re: RFC 31 - OGR 64bit Support (David Burken)
Message: 1
Date: Sun, 28 Nov 2010 23:24:56 -0500
Subject: Re: [gdal-dev] GDAL contouring problem
To: Ole Nielsen <ole.nielsen at aifdr.org>
Cc: "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>,
"adelebear at me.com" <adelebear at me.com>
Message-ID: <4CF32B18.2030208 at pobox.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Ole Nielsen wrote:
> I am posting this again without test files attached due the 50K size
> limit. Anyone who wants to see them, please contact me directly.
> We have observed interesting anomaly with gdal_contour when one of the
> fixed levels is zero.
> If the zero contour is expressed as 0.0 (or indeed 0.0000) gdal_contour
> replies with the standard Usage message (see below). If the zero contour
> is expressed as the integer 0 (or 0.00000001) it works and produces the
> expected contours.
Ole,
The gdal_contour program has some rather hokey heuristics to try and
recognise the end of the list of contour levels. The code looks like:
else if( EQUAL(argv[i],"-fl") && i < argc-1 )
while( i < argc-1
&& nFixedLevelCount
< (int)(sizeof(adfFixedLevels)/sizeof(double))
&& (atof(argv[i+1]) != 0 || EQUAL(argv[i+1],"0"))
&& !EQUAL(argv[i+1], "-3d"))
adfFixedLevels[nFixedLevelCount++] = atof(argv[++i]);
So basically, it assumes everything is a "level" until something that
has a numeric value of 0 is encounter that isn't the specific string
"0". So your analysis of the problem is essentially correct, but it is
more or less intentional as we try to support a list of levels with no
explicit "end of list" marker in the arguments to the command.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
Message: 2
Date: Mon, 29 Nov 2010 16:48:56 +1100
To: Frank Warmerdam <warmerdam at pobox.com>
Cc: "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>, Ole Nielsen
<ole.nielsen at aifdr.org>, "adelebear at me.com" <adelebear at me.com>
Message-ID:
<AANLkTi=xCXQx=Nx1hbnjqMb6WVr3VfL6AoQPQHeKx1nQ at mail.gmail.com>
Is there any reason not to include a heuristic that uses strtod() or
similar to test for the zeroness of the last argument?
-Francis Markham
>> replies with the standard Usage message (see below). If the zero contour is
>> expected contours.
> Ole,
> recognise the end of the list of contour levels. ?The code looks like:
> ? ? ? ?else if( EQUAL(argv[i],"-fl") && i < argc-1 )
> ? ? ? ? ? ?while( i < argc-1
> ? ? ? ? ? ? ? ? ? && nFixedLevelCount
> ? ? ? ? ? ? ? ? ? ? ? ? ? ? < (int)(sizeof(adfFixedLevels)/sizeof(double))
> ? ? ? ? ? ? ? ? ? && (atof(argv[i+1]) != 0 || EQUAL(argv[i+1],"0"))
> ? ? ? ? ? ? ? ? ? && !EQUAL(argv[i+1], "-3d"))
> ? ? ? ? ? ? ? ?adfFixedLevels[nFixedLevelCount++] = atof(argv[++i]);
> "0". ?So your analysis of the problem is essentially correct, but it is
> Best regards,
> I set the clouds in motion - turn up ? | Frank Warmerdam,
> and watch the world go round - Rush ? ?| Geospatial Programmer for Rent
