[gdal-dev] ERROR 4: ... is a grib file, but no raster dataset
was successfully identified.
brian
rush at winkey.org
Mon Oct 4 10:24:03 EDT 2010
Hermann
GDAL uses degrib to read grib files. I tryed the product in both degrib
and gribdump, neither app will read it. Either the grib file is corrupt
or it is a varient that neither app will read.
Brian
rush at octopi ~ $ degrib HRES_ENS_2010100300+000.grib2 -I
ERROR: with inventory, so far:
MsgNum, Byte, GRIB-Version, elem, level, reference(UTC), valid(UTC),
Proj(hr)
1.0, 0, 2, (null), (null), 01/01/1970 00:00, 01/01/1970 00:00, 0.00
ERROR: In call to GRIB2Inventory.
ERROR: Ran out of file in Section 1
ERROR: Problems with section 1
rush at octopi ~ $ degrib HRES_ENS_2010100300+000.grib2 -C -Csv
ERROR: In call to Grib2Convert.
ERROR: In call to ReadGrib2Record.
Inside ReadGrib2Record.. Calling FindSectLen
ERROR: Section 1 labeled as 21
rush at octopi ~ $ gribdump -v HRES_ENS_2010100300+000.grib2
Oct 04 14:21:53 gribdump[22297]: Starting Up
Oct 04 14:21:53 gribdump[22297]: oversize GRIB product 2
Oct 04 14:21:53 gribdump[22297]: GRIB product: 2
Oct 04 14:21:53 gribdump[22297]: GRIB product: 4
Oct 04 14:21:53 gribdump[22297]: GRIB product: 6
Oct 04 14:21:53 gribdump[22297]: GRIB product: 8
Oct 04 14:21:53 gribdump[22297]: GRIB product: 10
Oct 04 14:21:53 gribdump[22297]: GRIB product: 12
Oct 04 14:21:53 gribdump[22297]: GRIB product: 14
Oct 04 14:21:53 gribdump[22297]: GRIB product: 16
Oct 04 14:21:53 gribdump[22297]: GRIB product: 18
Oct 04 14:21:53 gribdump[22297]: GRIB product: 20
Oct 04 14:21:53 gribdump[22297]: GRIB product: 22
Oct 04 14:21:53 gribdump[22297]: GRIB product: 24
Oct 04 14:21:53 gribdump[22297]: GRIB product: 26
Oct 04 14:21:53 gribdump[22297]: GRIB product: 28
Oct 04 14:21:53 gribdump[22297]: GRIB product: 30
Oct 04 14:21:53 gribdump[22297]: GRIB product: 32
Oct 04 14:21:53 gribdump[22297]: GRIB product: 34
Oct 04 14:21:53 gribdump[22297]: GRIB product: 36
Oct 04 14:21:53 gribdump[22297]: GRIB product: 38
Oct 04 14:21:53 gribdump[22297]: GRIB product: 40
Oct 04 14:21:53 gribdump[22297]: EOF on input
Oct 04 14:21:53 gribdump[22297]: Exiting
Oct 04 14:21:53 gribdump[22297]: 0 WMO msgs, 0 GRIBs decoded, 0 written
On Mon, 2010-10-04 at 16:06 +0200, Hermann Peifer wrote:
> It is here for the next 10 days:
> http://transfer.eea.europa.eu/download/6694e0deb608337a8d0e6c1fb0ad5068
> Thanks for your time, Hermann
> On 04/10/2010 15:27, brian wrote:
> > Hermann
> > Do you have a link to the grib file you can share?
> > Brian
> > On Mon, 2010-10-04 at 15:16 +0200, Hermann Peifer wrote:
> >> Hi All,
> >> I am getting this error for a grib2 file:
> >> $ gdalinfo HRES_ENS_2010100300+000.grib2
> >> ERROR 4: HRES_ENS_2010100300+000.grib2 is a grib file, but no raster
> >> dataset was successfully identified.
> >> gdalinfo failed - unable to open 'HRES_ENS_2010100300+000.grib2'.
> >> I am using gdal from trunk which has, among others, support for these
> >> formats:
> >> $ gdalinfo --formats | egrep "JP|GRIB"
> >> JPEG (rwv): JPEG JFIF
> >> JPEG2000 (rwv): JPEG-2000 part 1 (ISO/IEC 15444-1)
> >> GRIB (rov): GRIdded Binary (.grb)
> >> I found some older postings to the mailing list on a similar error, but
> >> whatever was mentioned there did not help in my case.
> >> Hermann
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
