[gdal-dev] Re: Reading Geometry from text file
moritzzz
spam at kolix.de
Tue Oct 5 09:50:28 EDT 2010
So I now changed the code to just use the geos library and it works:
Point* kdTreeMgmtServer::process_polygon(string line, string path) {
WKTReader* wkt_reader = new WKTReader();
Geometry* geom = wkt_reader->read(line);
if(!geom->isValid()) {
log_error("not a valid geometry: %s\n", line.c_str());
return NULL;
if(geom->getGeometryTypeId() != GEOS_MULTIPOLYGON) {
log_error("geometry is not a multipolygon! geometrytype = %s\n",
geom->getGeometryType().c_str());
return NULL;
MultiPolygon* poly = (MultiPolygon*) geom;
Point* centroid = poly->getCentroid();
log_debug("centroid: %lf %lf\n", centroid->getX(), centroid->getY());
return centroid;
This code is now calculating the good centroid etc and the geos library
should offer enough functionality for my purpose. As soon as I have some
time I'll enable the debug and check out what's wrong with the gdal/ogr
stuff.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Reading-Geometry-from-text-file-tp5602472p5603175.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
