[gdal-dev] Re: GDAL JAVA problem
sagar_sahay sagar at spiffymap.net
Wed Oct 6 10:35:38 EDT 2010
After tweaking the path variable I got this exception:
Native library load failed.
java.lang.UnsatisfiedLinkError:
/home/gdal/gdal-1.7.2/swig/java/libgdaljni.so:
/home/gdal/gdal-1.7.2/swig/java/libgdaljni.so: wrong ELF class: ELFCLASS64
(Possible cause: architecture word width mismatch)
Exception in thread "main" java.lang.UnsatisfiedLinkError:
org.gdal.gdal.gdalJNI.AllRegister()V
        at org.gdal.gdal.gdalJNI.AllRegister(Native Method)
        at org.gdal.gdal.gdal.AllRegister(gdal.java:447)
        at ogr.gdalinfo.main(gdalinfo.java:57)
Java Result: 1
Please Help.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GDAL-JAVA-problem-tp2147356p5607309.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
