[gdal-dev] SQLite/SpatiaLite driver capabilities
Even Rouault
even.rouault at mines-paris.org
Wed Oct 6 14:23:30 EDT 2010
Le mercredi 06 octobre 2010 20:17:29, Alexander Bruy a écrit :
> Hi,
> Seems, that OGR reports wrong capabilities for SQLite/SpatiaLite layers.
> At least for DeleteFeature capability. I always get FALSE when test this
> capability, but I can delete features from layer passing to the ExecuteSQL
> method DELETE statement.
There are sometimes inconsistencies between actual capabilities and reported
capabilities, which is a bug then.
But in that case, it is not a bug. the DeleteFeature capability must be
reported if the layer has an implementation of OGRLayer::DeleteFeature(),
which the SQlite driver has not. The fact that it the SQLite SQL engine can
process DELETE statements doesn't influence that fact.
> Is this bug or feature?
So this is a "feature"
> Thanks
