[gdal-dev] ogr2ogr OCI: ORA-13349 and ORA-13356
Imran Rajjad
rajjad at gmail.com
Mon Oct 11 05:32:56 EDT 2010
Hi Sebastian
did you verify geometries ? there is a tool in esri arcmap that
validates and fixes geometries, I kind of had the same problem but I
applied correction through arcMap , and it worked.
regards.
Imran
On Mon, Oct 11, 2010 at 2:28 PM, Sebastian E. Ovide
<sebastian.ovide at gmail.com> wrote:
> Hi All,
> Importing shapes into Oracle I'm getting not valid geometrie: ORA-13349 and
> ORA-13356.
> No problem importing the same shapes into PostGIS.
> any ideas ?
> Sebastian E. Ovide
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I.R
