[gdal-dev] python GetDescription() returns empty strings on 1.7.1
Even Rouault
even.rouault at mines-paris.org
Mon Oct 11 10:43:02 EDT 2010
Selon Matthieu Rigal <rigal at rapideye.de>:
Matthieu,
I can reproduce in trunk too. I'm not aware that this issue was known. I'm even
a bit surprised this has worked before as the SetDescription() method in
GDALPamRasterBand doesn't seem to have been ever overloaded, so a bit of
investigation is necessary.
In 1.6.x branch, I suppose this worked before the band description was written
in a .aux.xml file ?
Best regards,
Even
> Hi folks,
> Currently running GDAL 1.7.1, I noticed a regression towards the 1.6.x branch
> which I could not find in the tickets.
> Teh GetDescription() always seems to return empty strings, except for just
> created file and just setted description...
> Here is a description of the bug, I don't think it is quite the expected
> result :
> >>> from osgeo import gdal
> >>> xT = gdal.GetDriverByName('GTiff').Create('test-desc.tif',10,10,1)
> >>> xB = xT.GetRasterBand(1)
> >>> xB.SetDescription('test')
> >>> xT = None
> >>> xT2 = gdal.Open('test-desc.tif')
> >>> xT2.GetRasterBand(1).GetDescription()
> The 1.6.1 returns:
> 'test'
> Is it a known bug ? Solved in further versions ?
> Regards,
> Matthieu
> RapidEye AG
> Molkenmarkt 30
> 14776 Brandenburg an der Havel
> Germany
> Follow us on Twitter! www.twitter.com/rapideye_ag
> Head Office/Sitz der Gesellschaft: Brandenburg an der Havel
> Management Board/Vorstand: Wolfgang G. Biedermann
> Chairman of Supervisory Board/Vorsitzender des Aufsichtsrates:
> Juergen Breitkopf
> Commercial Register/Handelsregister Potsdam HRB 17 796
> Tax Number/Steuernummer: 048/100/00053
> VAT-Ident-Number/Ust.-ID: DE 199331235
> DIN EN ISO 9001 certified
> Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte
> Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
> E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den
> Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
> die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
> The information in this e-mail is intended for the named recipients
> only. It may contain privileged and confidential information. If you
> have received this communication in error, any use, copying or
> dissemination of its contents is strictly prohibited. Please erase all
> copies of the message along with any included attachments and notify
> RapidEye AG or the sender immediately by telephone at the number
> indicated on this page.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
